building bottem end help??
Old Oct 7, 2009 | 02:26 PM
b20btegg's Avatar
Default building bottem end help??
well i wanna start building my bottom end for my turbo set up, im new to this and dont really know what to do besides sleeves, what all do i need to do to build a reliable bottom end that will hold up for a long time??
Old Oct 7, 2009 | 02:31 PM
slowboy90's Avatar
Default Re: building bottem end help??
you will need a good set of rods (Pauter, Manley, Eagle if running moderate power), forged pistons (many to choose from), good machine work
Old Oct 7, 2009 | 02:37 PM
2BARtypeR's Avatar
Are you getting the work done locally or? I sent my block to ERL. They put the JE pistons in, Manley Rods, Sleeves, ect ect.
Old Oct 7, 2009 | 03:03 PM
jdmcoop's Avatar
Depending on horse power goals ERL has several different packages for rotating assembles to chose from. You can check out our website and go to the engine catalog to get some good info. Also we have tech articles that help understand our sleeving/machining methods.
Old Oct 7, 2009 | 04:28 PM
b20btegg's Avatar
about how much did that cost you 2bar?
Old Oct 7, 2009 | 07:15 PM
HeikDiesel's Avatar
You can expect 2000+ for an assembled bottom end.
Old Oct 7, 2009 | 08:01 PM
turbociv910's Avatar
ERL, Laskey, GE.. seen/heard good stuff from all
Old Oct 7, 2009 | 09:51 PM
2BARtypeR's Avatar
Roughly $3900 with the ARP bolts and the cometic gasket.
I attached a page with some of their prices.
Also you can see the details of each short block package they have in the link below. Check out page 10, which is the "C2" package.
http://erlperformance.com/images/sto...talogFINAL.pdf
File Type: pdf
Str8fourvtec
Mar 26, 2010 05:46 PM
accord_raffi
Aug 2, 2008 02:26 PM
mawkiemarc
Sep 28, 2005 05:43 PM
Matty
Mar 4, 2005 07:38 AM
Citystar
Jun 23, 2004 06:20 PM
