BTM or Headgasket, which one would you pick!?!?!
What up yall, Which would you go with for the best detonation prevention? Head gasket of Boost Timing Master? I have a 99 GSR, boosted @ 7PSI and the pistons cracked from detonation after having the turbo on for one week.
Re: BTM or Headgasket, which one would you pick!?!?! (99GSRT)
I'd say better fuel supply or management...what are you running? Also if interested I have a cometic HP gasket for the GSR brand new for $90, but I dont think a HG provides detonation prevention.
Re: BTM or Headgasket, which one would you pick!?!?! (BoOsTeD_eK)
My parts list is in my sig. Thanks for the offer on the gasket, but If I buy one I'm going with the R-Ideal gasket.
(http://www.f-max.com/Detonation%20Management-Honda.htm)
your car should not be detonating at 7psi with your set-up.
you have other issues you need to sort out first.
the btm is garbage and the cost of the head gasket/labor is definitely not worth.
Re: BTM or Headgasket, which one would you pick!?!?! (itr206)
The rIdeal head gasket is a combination of two stock headgaskets with a copper plate sandwiched in between. The idea behind this is that it will lower your compression thus "preventing" detonation.
Re: BTM or Headgasket, which one would you pick!?!?! (DRAGLS)
Your signature says your setup, however it doesnt say what you have for fuel delivery/management...what is it?
Re: BTM or Headgasket, which one would you pick!?!?! (SpoolinLS)
I have a MSD In-line fuel pump and Boost dependent fuel pressure regulator, that's it. My engine is being rebuilt as we speak and I want to ensure I don't crack and pistons again! I only had the turbo on for a week for God's sake! While I had the car running, it was unable to go full throttle over 4500 rpm before the boost would just cutout. I could go 3/4 throttle all the way to 7500rpm though.
