breather ports
hey i was wondering where can i buy the breather ports that go on the back of honda blocks. i believe they are off the z10 car that older preludes. thanks
Re: breather ports (slickvic)
I took my stock ones out and drilled holes in them. Then I welded steel -10 bungs on them. Only $10 each from Summit.
https://honda-tech.com/zerothread/2022061
He sells them. Check out the link! https://honda-tech.com/zerothread/2022061 |
ive got a pair if you want em bought from Honda never fitted tho, u in the uk?
thanks guys for replying but are there any other ones
Go with B&R Fittings...You will not be let down
Re: breather ports (nitroice40)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitroice40 »</TD></TR><TR><TD CLASS="quote">I took my stock ones out and drilled holes in them. Then I welded steel -10 bungs on them. Only $10 each from Summit.</TD></TR></TABLE>
if you're on a budget or dont want to wait, you could buy those at a local hydraulic shop or NAPA for less than half that. Just ask for JIC fittings |
i tried emailing and pm b&r fitting but no response
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slickvic »</TD></TR><TR><TD CLASS="quote">i tried emailing and pm b&r fitting but no response</TD></TR></TABLE>
I sent you a PM yesterday with the price. They are $45 shipped to the lower 48 states. I never received an email. bandrfittings@gmail.com Thanks |
