break in injector ?
Old May 8, 2010 | 05:02 PM
CivSiClone_96's Avatar
Default break in injector ?
hey i just rebuilt my lsvtec I got block honed and resurfaced, new rings, and bearings my question is im running 680cc injectors with a resistor box I plan on letting the car idle through a few heat cycles then driving it straight to my tuner but my tuner is about 40 miles away from where I am at so I just seeing if running those injectors at first start up would be ok??? i dont want to flush the rings. Thanks
Old May 8, 2010 | 05:14 PM
victor.ek4's Avatar
Default Re: break in injector ?
It's not ok.
I'd put the stock injectors back and run a GSR basemap atleast..
edit: Oh, it's boosted, lol.
Then NO, it's not ok anyway. get at least a partial tune with safe AFR's and timing for cruising 40 miles
Old May 9, 2010 | 12:54 AM
lol I have a aem wideband and I plan on not even taking it over 3k when I drive it to my tuner im not even going to touch boost until the motor is tuned.
Old May 9, 2010 | 05:54 AM
noboostedEGo's Avatar
rpm isn't as important as load...low rpm with higher load is one of the most dangerous conditions for an untuned motor.
not to mention, load or not, your motor is not going to run on 680s without fuel adjustments. as stated, at least get a basemap to drive on to go to your tuner.
Old May 9, 2010 | 06:24 PM
ya I will get a base map put on it to atleast then drive it to my tuner he will break it in on the dyno.
Old May 9, 2010 | 06:50 PM
sjp00422's Avatar
TRAY-LER!!!
Old May 9, 2010 | 07:11 PM
Turbo-LS's Avatar
Stock injectors stock ecu stay out of boost, remove bov if you have to to vent any possible boost build up. the motor needs to be broken in by varying rpm and load to seat the rings properly. not doing this will cause ring issues and ANY basemap is going to cause more than lilely to rich of a condition and rings will not seat properly
JeffBro
Engine Management and Tuning
Jun 22, 2011 06:49 AM
N20civicB18
May 15, 2006 02:25 PM
Turbocivic94
Mar 8, 2006 07:49 PM
X2BOARD
Jul 8, 2004 11:22 AM
