Brakes with turbo?
Old Feb 5, 2004 | 01:14 PM
-Trinitron-'s Avatar
Default Brakes with turbo?
Maybe I am a retard but I was looking at the diagram on Golden Eagle's site for the vacuum manifold. I noticed the brake vac lines that normally operate under vacuum, are now seeing pressure. How do your brakes function properly without the vacuum? Did I misread something?
*If I am retarded, just reply "yes, you are retarded." An elaborate flaming is not required!
Old Feb 5, 2004 | 01:18 PM
2.2's Avatar
2.2
Default Re: Brakes with turbo? (-TRINiTRON-)
How often do you get into boost while pressing on the brakes to stop at the same time? Probably never. When you are coasting to a stop and have the throttle closed, your engine is under vacuum.
Kenton
Old Feb 5, 2004 | 01:44 PM
Default Re: Brakes with turbo? (2.2)
Thanks Kenton, that actally makes a lot of sence. I appreciate the quick answer. I guess that would explain the check valve in the line too! <--me
jarrodsi
Suspension & Brakes
Dec 1, 2015 04:34 PM
whited
Aug 6, 2012 12:18 PM
ant$missShift
Jul 29, 2008 12:11 PM
djnikko
Sep 15, 2004 04:05 AM
GruvyTune
Aug 28, 2001 11:33 AM
