BOV question
Old Apr 3, 2006 | 11:49 AM
NeWnMpR0VeD's Avatar
Default BOV question
i have a universal greddy type s (purple cap) blow off valve... i stripped the threads on the inside where you adjust the screw for the volume of the BOV... is there a place that sells just the purple cap (top part of the bov) by itself ??? i remember seeing a site on here but i cant find it anymore... any help would be good
and yes, i know... pretty random
Old Apr 3, 2006 | 11:50 AM
Soccerking3000's Avatar
Default Re: BOV question (NeWnMpR0VeD)
just take the cap off, drill it out and then retap it with a larger tap and just get a larger bolt to go in it, problem solved
Old Apr 3, 2006 | 11:55 AM
Default Re: BOV question (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">just take the cap off, drill it out and then retap it with a larger tap and just get a larger bolt to go in it, problem solved </TD></TR></TABLE>
LOL i was thinking that, BUT i'm sure the screw has to be a certain length... and a certain type
Old Apr 3, 2006 | 11:59 AM
not really, the screw just compresses the spring inside the cap, however it does fit in an indentation on the cap of the spring, you can just file the bolt down slightly to make it work.
Old Apr 3, 2006 | 12:03 PM
k thanks, i'll try that
Old Apr 3, 2006 | 12:04 PM
Default Re: (NeWnMpR0VeD)
no problem keep us updated when/if you fix it
Eklsv-t
Nov 23, 2007 06:00 AM
abmerop18
Aug 4, 2007 06:00 PM
Integra21
Apr 21, 2006 10:20 AM
FOrSfEd
Mar 8, 2004 03:14 PM
pdiddy
Dec 29, 2002 08:03 PM
