bov not sounding right?
Old May 21, 2007 | 10:40 PM
krazyhmongboi's Avatar
Default bov not sounding right?
so we bought a boosted integra for my brother and when we pushed it we noticed the blow off valve didnt sound like we'd expect it..we went on youtube and searched the sound of the greddy type rs and ours sounds alot different then theres..the car is tuned at 1.2 bar..people say to get a better sound the boost needs to be high but with my greddy type s at 9 pounds it sounds way louder than his..what could b the problem..all vacuum lines are perfect
Old May 22, 2007 | 05:38 AM
dfdon3's Avatar
what does it sound like that would make you think this?
Old May 22, 2007 | 07:59 AM
it just sounds like a short whoosh of air
for example im thinking it should sound like this
http://youtube.com/watch?v=Hi6ISfHziMs
yea mine is nothing like that haha
Old May 22, 2007 | 08:05 AM
1158's Avatar
The RS is supposed to be quieter than the S. I have one for that very reason.
Try this page...http://www.blowoffvalves.com/ and watch one of the Greddy RS clips. Sounds similar to mine.
Old May 22, 2007 | 12:55 PM
yea i checked that site thats why i figured something was wrong with my bov cause it didnt even make a loud whoosh or air but just a little quiet one
Old May 22, 2007 | 01:20 PM
1158's Avatar
Maybe check the adjustment. If it's adjusted loose it would have less of a whoosh to it.
Old May 22, 2007 | 01:36 PM
u know how the nipple is able to be skrewed in and out of the bov..is it suppose to be skrewed in as far as it can by hand or does it not matter?
Old May 22, 2007 | 01:51 PM
da_dude's Avatar
Default Re: (krazyhmongboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazyhmongboi &raquo;</TD></TR><TR><TD CLASS="quote">u know how the nipple is able to be skrewed in and out of the bov..is it suppose to be skrewed in as far as it can by hand or does it not matter?</TD></TR></TABLE>
Are you talking about the vacuum nipple or the adjustable allen wrench? For the vacuum nipple just tight it by hand. You don't want to shred the tread so hand tight is fine. If you worry about leaks than put som typlon tap around it and put it back on. For the adjustable allen wrench, you don't want it too tight or too lose. In between where it won't leak and won't have compression surge.
Old May 22, 2007 | 02:19 PM
1158's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1158 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe check the adjustment. If it's adjusted loose it would have less of a whoosh to it.</TD></TR></TABLE>
I was speaking of the adjustable allen wrench, as pointed out by turb20_vtec. Make sure you loosen up the lock nut or you can strip the housing.
Old May 22, 2007 | 02:34 PM
allen wrench? i gotta take a better look at the bov i guess
Old May 22, 2007 | 05:32 PM
civic_saints1's Avatar
Whats wrong with the HKS Sequential BOV besides the price tag on it?Any good or bad comments about that one, cuz my friend has it on his DSM and I really like the sound of that bitch!!!
Old May 22, 2007 | 05:43 PM
sohc_turd's Avatar
Default Re: (civic_saints1)
Regardless of the adjustments made, i'd just make sure that its holding the boost level you are operating at and that you are not getting compressor surge, other than that who cares about the sound.
Old May 22, 2007 | 06:08 PM
1158's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_turd &raquo;</TD></TR><TR><TD CLASS="quote">Regardless of the adjustments made, i'd just make sure that its holding the boost level you are operating at and that you are not getting compressor surge, other than that who cares about the sound.</TD></TR></TABLE>
Agreed, but if it's sounding soft, it may mean it's not adjusted properly and opening up a bit under boost. If it's not doing that and you have no surge, then it doesn't matter.
JDM_SOHC
Dec 11, 2008 06:05 PM
TURKISHFORCE
Apr 25, 2006 02:29 PM
CivicEJ1
Dec 29, 2004 04:59 PM
Maddox
Jan 9, 2004 01:22 PM
GOLDBERG
Nov 26, 2002 09:10 AM
