BOV flutters
Old Nov 14, 2002 | 01:19 PM
Night_Minx
Guest
Posts: n/a
Default BOV flutters
Is this typical of low boost cars-6psi? Im using a BOV from japan, its called a MUSASHI-dont ask me why- anyway, its off a R32, and i can only get it to flutter. I cant feel any lag whatsoever between shifts, its definetly venting, but is it doin it enough? Ive also heard that i should hook it up to its own VAC source. Right now its t'd off the FPR line along with the dashpot VAC line. ANy suggestions??? Am i OK? the screw on the top loosened all the way. doesnt open at idle either-
heres the beast on my mini-skyline:
[Modified by Night_Minx, 10:22 PM 11/14/2002]
Old Nov 14, 2002 | 01:42 PM
pelotudo's Avatar
Default Re: BOV flutters (Night_Minx)
Try hooking it up to the brake booster. I had my BOV hooked up to the FPR, then directly to the mani, and for somer reason it still wouldn't work until I finally hooked it up to the massive brake booster line...
jB
Old Nov 14, 2002 | 02:20 PM
BoostedH23a1's Avatar
Default Re: BOV flutters (PeloTudo)
how big is the valve in it? if its small its gonna flutter like the SSBOV
Old Nov 14, 2002 | 03:25 PM
sushibug's Avatar
Default Re: BOV flutters (BoostedH23a1)
off a skyline huh? my guess is yer not running enough boost. if it is adjustable, tighten it so its more sensitive to boost.
fyi when i had my greddy type s, it didnt matter what vac source i ran it from.
[Modified by sushibug, 12:25 AM 11/15/2002]
Old Nov 14, 2002 | 06:16 PM
turbologist's Avatar
Default Re: BOV flutters (sushibug)
If you have it T-eed that could be your problem, you need to make sure that it has a dedicated vacuum source. Or it may be b/c you have a stiff spring in there. Usually stiff springs come in the high performance BOVs, not like greddy or the other smaller ones. First try the dedicated vacuum, if that doesnt work, then try to find a way to adjust the spring, if that doenst work then see if u can take it apart and get a softer spring for it..HTH
superslow-oto
Nov 6, 2007 02:42 PM
boosted_duece
Nov 23, 2005 09:29 PM
BoostedSOHC
May 21, 2003 06:52 AM
HondaCutter
Sep 26, 2002 04:20 PM
