bought this block how much hp is it good for?
Old Aug 24, 2007 | 07:10 PM
buffgsr's Avatar
Default bought this block how much hp is it good for?
b18a block
Wiseco 8.5:1 Forged Pistons (PN# K541M81)
Eagle H-Beam Rods (PN# CRS5394A3D)
Micropolished and Balanced Crank by Jackson Cylinder Head
Honed by Jackson Cylinder Head
whats the most hp i can get on this safely for everyday driving this a b18a block with a gsr head ls/vtec turbo
Old Aug 24, 2007 | 07:46 PM
TDCTyler's Avatar
Default Re: bought this block how much hp is it good for? (buffgsr)
if this motor was very well built, id say it can handle 600-800 hp easily.
Old Aug 24, 2007 | 08:15 PM
bigbadboy's Avatar
does it have stock sleeves
Old Aug 24, 2007 | 09:00 PM
quicksilver1689's Avatar
i ♥ snails
Default Re: bought this block how much hp is it good for? (TDCTyler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TDCTyler &raquo;</TD></TR><TR><TD CLASS="quote"> if this motor was very well built, id say it can handle 600-800 hp easily.
You sure?
Old Aug 25, 2007 | 05:13 AM
buffgsr's Avatar
stock sleeves
Old Aug 25, 2007 | 06:15 AM
HiProfile's Avatar
There have been 560whp bone-stock b16's, albeit they only lasted a few runs before the ringlands cracked, but the sleeves can take 500whp for quite some time. They only crack when you run too much timing, have a big boost spike (lean out), or anything else that creates detonation. Most of the cracked sleeves happen on cylinder #3, which is the hottest running cylinder ...its no coincidence, as a hotter cylinder will be more prone to pre-ignition/detonation.
Old Aug 25, 2007 | 01:21 PM
iTz On!!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buffgsr &raquo;</TD></TR><TR><TD CLASS="quote">b18a block
whats the most hp i can get on this safely for everyday driving this a b18a block with a gsr head ls/vtec turbo</TD></TR></TABLE>
you should keep turning up the boost and tell us when it blows... then the psi your at minus like 2lbs or something and thats how much the block can handle.
Old Aug 28, 2007 | 01:29 AM
Equilibrium's Avatar
* B A N N E D *
Default Re: bought this block how much hp is it good for? (NyTeRyDeR gSr)
yeah, BLOW THAT **** THE expletive UP! Then let us know so we can better our builds...
Old Aug 28, 2007 | 11:41 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NyTeRyDeR gSr &raquo;</TD></TR><TR><TD CLASS="quote">
you should keep turning up the boost and tell us when it blows... then the psi your at minus like 2lbs or something and thats how much the block can handle.</TD></TR></TABLE>
lol.
I'd probably cut it off around 400-450whp. You can go more if you'd like.
a1320honda
Mar 8, 2008 09:07 AM
paulzy
Oct 23, 2006 05:22 PM
92redhatch
Mar 5, 2006 05:52 PM
Attoir
Oct 21, 2004 04:34 AM
allmotorls95
Apr 21, 2003 10:38 PM
