Bosch Pump need help Identifying
Old May 5, 2010 | 05:00 AM
TopEndTuner's Avatar
Default Bosch Pump need help Identifying
I am getting ready to convert my turbo car to E85 and I was going to buy a Bosch 044 pump. I was telling a friend about it and he gave me a Bosch High Flow Fuel Pump that he had bought for a previous project. The number is 0 580 254 996 and I'm having difficulty getting information on the flow rate of this particular pump. Somebody help me out here guys.
Old May 5, 2010 | 06:28 AM
Default Re: Bosch Pump need help Identifying
Come on guys somebody's gotta know about this pump....I've been Google and Bing ing all morning
Old May 5, 2010 | 10:17 AM
96 GSR-T's Avatar
Part Number........ litres / hour ......(pressure)
0 580 254 023........... 168............ (5 Bar) (72psi)
0 580 254 040........... 102............ (6.5 Bar) (94psi)
0 580 254 044........... 200 ............(5 Bar) (72psi)
0 580 254 046........... 207............ (3 Bar) (43psi)
0 580 254 053........... 175............ (5 Bar) (72psi)
0 580 254 909........... 148............ (5 Bar) (72psi)
0 580 254 910........... 130............ (5 Bar) (72psi)
0 580 254 911........... 95.............. (4 Bar) (58psi)
0 580 254 975........... 165............ (5 Bar) (72psi)
0 580 254 979........... 165............ (5 Bar) (72psi)
0 580 254 984........... 165............ (5 Bar) (72psi)
0 580 464 069........... 98.............. (4 Bar) (58psi)
0 580 464 070........... 130............ (3 Bar) (43psi)
B 261 205 413.......... 200............ (8 Bar) (116psi)
I cannot find a Bosch Pump ending with the part #996...... Are you sure its not a bootleg? Post pics....
Old May 5, 2010 | 10:58 AM
Yeah I'm taking pics now but you can see where my issue is now
Old May 5, 2010 | 11:12 AM
Captain Bondo's Avatar
That is a pump as used in Volvo 240's with k-Jetronic which is a high pressure mechanical fuel system. It's a decent pump and like most b osch pumps performs well with high system pressures.
They're good for 400-450whp with a decent in-tank pump feeding them.
Edit: never mind that is from a naturally aspirated 240 not a turbo. Turbo's use the 984. I don't know what the 996 flowes but presumably less than the turbo pump.
Old May 5, 2010 | 11:20 AM
Well I'm wanting to go to E85 and my setup already made 464 on pump with a walbro 255. I'm installing a surge tank and mounting this Bosch inline to feed the engine w/ the Walbro feeding the Surge. Think I'll have an issue? Here's some pics
Old May 5, 2010 | 12:25 PM
96 GSR-T's Avatar
044's are $190..... and the guy that posted before you last posted pretty much summed it up.
Old May 5, 2010 | 02:34 PM
Agreed on the 044. It is probably a bad plan to just install a used pump of unknown capacity and just hope for the best.
honda_joe
Feb 13, 2007 02:40 PM
94lsvtec
Suspension & Brakes
Jul 28, 2005 07:11 PM
