Boring and HeadGasket sizes ????
Old Feb 11, 2002 | 01:30 AM
BLKCRX's Avatar
Default Boring and HeadGasket sizes ????
hey all, after much deciding.. iv almost chosen to bore my b16a out to 1727.25cc's with an 84.5mm bore (also sleeving it also to 84.5mm) and order my 84.5mm pistons...
but.. i was just wondering... if i chage my bore size does that mean i need a larger headgasket.. ie 84.4mm instead of or would i just get my mechain shop to bore out a new headgasket also ?
also is there anything else i need to do to my engine... once its bored / sleeved to tell the hondata ecu that it can now pump more fuel in bc its a 1727cc engine ???
b/w iv gone for a 9:1 JE pro ratio pistons with new Eagle rods... also for my engine rebuild.
Regards James
[Modified by BLKCRX, 8:34 PM 2/11/2002]
Old Feb 11, 2002 | 03:58 AM
internet ay's Avatar
Default Re: Boring and HeadGasket sizes ???? (BLKCRX)
i was also curious to the answer to that question because i am sending my ls block out to golden eagle this week and boreing it out to 84.5, i am thinking that maybe i could use a b20 headgasket and trim it though. might work.
[Modified by internet ay, 8:05 AM 2/11/2002]
Old Feb 11, 2002 | 06:48 AM
b18bturbo's Avatar
Default Re: Boring and HeadGasket sizes ???? (internet ay)
just go get a cometic gasket. They make them in many bore sizes. Contact the guys at raceeng.com
Old Feb 11, 2002 | 08:08 AM
Default Re: Boring and HeadGasket sizes ???? (b18bturbo)
thank you
Old Feb 11, 2002 | 09:25 AM
VaporTrail's Avatar
New User
That's what I did!
Old Feb 11, 2002 | 04:47 PM
boosted3g's Avatar
Default Re: Boring and HeadGasket sizes ???? (VaporTrail)
Just an FYI, the B20 head gasket actually measures 85mm even though the bore is 84mm. Strange but true.
Old Feb 11, 2002 | 04:57 PM
InfamousRS's Avatar
Default Re: Boring and HeadGasket sizes ???? (boosted3g)
What about when I bore my stock sleeves out .5mm. Will the stock b18b HG still work out alright?
stocker2shocker91
13
Oct 17, 2007 09:33 AM
MysteriousGSR
Nov 19, 2002 08:47 AM
KooK
Mar 27, 2002 05:37 PM
BLKCRX
Feb 12, 2002 10:12 AM
93B17A
Feb 4, 2002 03:08 PM
