Borg Warner S362 Turbo
Old Mar 15, 2008 | 12:00 AM
90TegraB18C's Avatar
Default Borg Warner S362 Turbo
Just wondering what are you guys using for the oil feed for the S362 turbo. -3 or -4 line? Also, on the fitting just a normal fitting or a fitting with a Restrictor built into it?
Also, what would you guys suggest using to brace this turbo on a ram horn manifold? The turbo is about 30-35 lbs... Any pictures or info would be great.
Thanks
Old Mar 15, 2008 | 06:03 AM
turbodano's Avatar
Default Re: Borg Warner S362 Turbo (90TegraB18C)
Use the -4 line. The journal bearing turbochargers need the extra oil fow to keep them alive at high rpm. Just make sure your drain is real nice and free flowing.
I am not sure what to tell you for bracing on the unit.
Old Mar 15, 2008 | 07:31 AM
Turbo-charged's Avatar
Default Re: Borg Warner S362 Turbo (turbodano)
-4 feed, -10 return.
if your ramhorn manifold was built correctly it wont need any bracing. we run s372's on full race manifolds with out any problems, and they are much heavier than the s362
Old Mar 15, 2008 | 09:02 AM
TheShodan's Avatar
Moderator
Default Re: Borg Warner S362 Turbo (Turbo-charged)
Both of the above got it right. -4AN w/ 1/4NPT fitting, -10AN return.
golf-mk3
Mar 25, 2011 07:01 PM
My JDM EJ8
Dec 30, 2008 06:57 PM
central_driver
Mar 11, 2008 01:38 PM
J_Pemb
Jun 30, 2005 08:01 PM
phreakmang
Jul 6, 2004 07:49 AM
