Borg Warner s200 Turbo help.
Old Sep 19, 2010 | 10:54 AM
GEN2 LS's Avatar
Loved
Default Borg Warner s200 Turbo help.
looking at buying this turbo, specs say it only flows 35 lb/min so i'm currently running a 60 trim which looks to flow more. just need to make sure i'm looking at the right specs for the turbo, since borg warner has no many different variations of s200's! how much power can this thing make?
Old Sep 19, 2010 | 01:31 PM
TheShodan's Avatar
Moderator
Default Re: Borg Warner s200 Turbo help.
S200 is so general, you need to take those covers of find out which inducer/exducer you have. Either way, the exhaust wheel used from a box unit like that (It is NOT an S256/S259) uses an 80mm exhaust wheel over 30% larger than your stage III. THe question is whether or not it makes power, its more like, is it worth changing your entire setup for this box unit?
Old Sep 19, 2010 | 01:54 PM
ScorpionT's Avatar
Thats the 46mm compressor. It will make ~350whp maxed out.
Old Sep 19, 2010 | 02:12 PM
TheShodan's Avatar
Moderator
Good call.
AZ_CIVIC
Oct 31, 2014 01:50 PM
pantherballhp
Dec 13, 2010 01:13 PM
spooledb20
Sep 7, 2008 01:00 PM
Flr Power
Apr 3, 2004 01:33 PM
Acura_I-RS
Feb 23, 2003 06:41 PM
