bore and stroke
Old Oct 18, 2006 | 05:00 AM
NA_B18C1's Avatar
Default bore and stroke
whats the max the b16a2 and stroke and piston bore? also i forgot to add in whats the best compression to get up to the 400-500whp?
Old Oct 18, 2006 | 05:36 AM
adseguy's Avatar
Default Re: bore and stroke (NA_B18C1)
Don't worry about boring or stroking a stock sleeved B16. It's just not worth it as the power gains can be seen by adding just 1-2 lbs. If you are sleeving then I think 87mm (or more I'm not sure) is possible and with a stroker kit you can probably get into the 2.4L region.
On stock sleeves though I wouldn't go past 81.5mm (.5 overbore) and the max IS 82mm.
Compression....well that's up to you. Most like to stay on the med-low side with 9.0 and some like the off boost response of the 10.0:1 and up.
Old Oct 18, 2006 | 05:39 AM
NA_B18C1's Avatar
so i guess..it wouldn't matter much. if i were to use the eagle crank stroke 3.433" for the b18c1-c5 would the b16a2 block have to be special fitted in or will it be a just dropp in crank? thanks
enriquez2000
Feb 11, 2012 07:12 PM
7rrivera7
Apr 5, 2009 06:32 AM
TRUcrxEr
May 27, 2008 02:02 PM
jdmsijdm
Apr 13, 2006 11:48 AM
spark plugs.
Jun 2, 2004 10:57 AM
