bore sizes for forced induction (turbo)
Old Mar 4, 2005 | 09:40 AM
JDM00SI's Avatar
Default bore sizes for forced induction (turbo)
sup,
im currently looking to turbo my b16.....i always hear of people boring out thier engines in order for it to run better with the turbo. What sizes do you bore your engine out too? i always hear of people sleeving the engine, please correct me if im wrong, but is that just a layer around the cylinders to make it safer or what? can someone please explain it to me.
sorry for newbie questions,
thanks
Old Mar 4, 2005 | 09:46 AM
turboEGhatch's Avatar
Default Re: bore sizes for forced induction (JDM00SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI &raquo;</TD></TR><TR><TD CLASS="quote">sup,
thanks</TD></TR></TABLE>
Sleeving your motor consists of a shop cutting out the top portion of the stock cylinders and machining in new pieces. They are stronger than the stock sleeves, and you can bore them out further. Stock 81mm B series bores arn't safe to anything past 82mm realisticly. The advantages of a larger bore are slightly quicker spool, and slightly better head flow. You don't really notice much difference from 81-84MM on the street though.
Old Mar 4, 2005 | 09:52 AM
JDM00SI's Avatar
Default Re: bore sizes for forced induction (turboEGhatch)
if i have some low compression pistons.... wouldnt it be already sleeved?
Old Mar 4, 2005 | 09:56 AM
SSS2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI &raquo;</TD></TR><TR><TD CLASS="quote">if i have some low compression pistons.... wouldnt it be already sleeved?</TD></TR></TABLE>
You need to do some more research before going turbo
Old Mar 4, 2005 | 10:01 AM
Search a bit more. Lots of people run forged pistons in stock B series sleeves.
Mar48
Honda S2000
May 3, 2008 01:34 PM
IntegraPir4te
Dec 29, 2006 08:14 PM
dinku27
Sep 15, 2005 01:34 PM
PnoyJeff
Jan 26, 2005 03:22 PM
DenizenSays
Sep 21, 2004 03:36 PM
