boosting my setup??
Old Apr 17, 2003 | 11:25 PM
nick.na's Avatar
Default boosting my setup??
here's my mods so far:
B16a CRX SI
skunk2 stage 2 cams
skunk2 manifold
skunk2 chipped ecu
skunk2 cam sprockets
crower valve springs/oem typer retainers
jet chipped control module
race cat ,mid pipe,
magnacore 8.5 plugs
str cam seal
would I be able to safely run mild boost (6 psi possiby?) I rev pretty high rightnow...compression is supposed to be lower fr turbo, right...would a copper head gasket or other lower it enough to be safe with boost? would this be necessary? If I did lower the compression would this really lower the revving alot (I am assuming yes)
after all this...If it is possibly what turbo would best suit? any welp would be appreciated
Old Apr 18, 2003 | 06:12 AM
nick.na's Avatar
Default Re: boosting my setup?? (amber-bling)
up please help?
Old Apr 18, 2003 | 07:21 AM
nick.na's Avatar
everything I am reaing says I should be fine boosting jus tthrow my gsr cams back in. What kind of setups are you using to pull through on top end too?
EGCoupeVtec
Feb 11, 2009 06:00 AM
angela_itr
Sep 18, 2005 08:47 AM
WVTURBOCRX
Jun 28, 2005 01:38 PM
Blazeone
Jun 1, 2004 10:03 AM
