Boosting a D series.... have a question.....
Old Apr 11, 2005 | 10:47 PM
stock00civic's Avatar
Default Boosting a D series.... have a question.....
Well i am pretty much done with gathering my parts for my custom set up..... now I have a question. Right now the motor is stock. If possible I would like to boost 10psi and hit around 215-230whp. Does that sound like a reasonable number to run on a stock D series? I have seen people on here making around that much power, but when I asked someone that would be helping me with my install/tune he said that might be a bit much. The car is my daily driver, so its not like I'm going to be beating on it all the time. Any help would be appreciated.
Old Apr 11, 2005 | 11:04 PM
beerbongskickass's Avatar
Default Re: Boosting a D series.... have a question..... (stock00civic)
As long as the car is tuned well you should be fine, but I would try and keep it around 200whp daily just to be safe, then turn it up when racing if you want. I guess it you don't beat on your car very hard you can run more boost daily. I run about 215whp (9-10psi) daily, more at the track (12-14psi), and I have been raping the **** out of my car for about 14 months everytyime I drive it. When I bought the car it only had 64k miles though, it has 103k miles now, and I did buy it from a girl. But yeah just get some good fuel management and have it tuned well and don't be suprised if a rod snaps, they are pretty tiny.
Modified by beerbongskickass at 8:20 AM 4/12/2005
Old Apr 11, 2005 | 11:14 PM
cbrodac0424's Avatar
Default Re: Boosting a D series.... have a question..... (beerbongskickass)
i agree with beer tuning is what is going to keep your car together so make sure you have a respected tuner tune your car and you should be good. best of luck to you on your build.
Old Apr 12, 2005 | 01:45 AM
Sivik's Avatar
tuning and yea you can run 10 psi daily. unless you have 2 seperate fuel curves i'd suggest tuning for one boost level and leaving it there.
Old Apr 12, 2005 | 04:36 AM
Default Re: (Sivik)
Thanks for the replies. I am going to be tuned with Hondata and I am more than likely going to Velocity Performance to let Stoney work his magic.
Old Apr 12, 2005 | 05:10 AM
Boltz's Avatar
Default Re: (stock00civic)
Isn't Tony Palo out there in texas?
As long as your motor is in good shape you could run upwards of 250hp
with a proper tune of course
Old Apr 12, 2005 | 09:44 AM
Thanks for the info. Does anyone else have any comments or perhaps personal experiences?
Old Apr 12, 2005 | 10:45 AM
Devine's Avatar
Just have them tune your car very conservative and it will run forever, and watch out for what kind of gas you use, one bad tank and i now have 10% leak down in one cylinder luckily i heard the detonation.
Old Apr 12, 2005 | 11:12 AM
liam821's Avatar
25 Year Member
Default Re: Boosting a D series.... have a question..... (Devine)
I used to run 10psi daily on my old stock sohc back in the day. Tuning is key. It should make around 200-220whp depending on the setup and tuning.
liam
Old Apr 12, 2005 | 08:41 PM
Default Re: Boosting a D series.... have a question..... (liam821)
Sounds good. I think that I am going to run 10 psi after reading what you all are telling me.
Old Apr 12, 2005 | 09:53 PM
SOHCmaster's Avatar
I got a 00 civic ex used to have a NX kit w 50shot for a whole summer, later fabed up turbo kit and been runnin 8-10psi for going on 2 years now daily driven and race almost every weekend and drive it hard.. The car is still kickin strong for a stock internal Y8
Old Apr 12, 2005 | 11:09 PM
Drew Peacock's Avatar
Default Re: (PK SPEED)
Yeah run less boost everyday if you want it to last but upto 250whp can be made but your are pushing I did it for quitw while without engine problems.
Jkor
May 14, 2009 04:48 PM
foxdecoy
Dec 8, 2008 10:30 AM
cons
Jun 13, 2005 01:19 PM
egvtec
Apr 26, 2005 07:00 PM
EMphaticONE
Jan 17, 2005 08:23 PM
