Stock B16 and Boosting question.
Old Apr 17, 2006 | 04:43 PM
88crxhfb16's Avatar
Default Stock B16 and Boosting question.
How much Boost is safe to run on a built stock block bored 81.5??
Old Apr 17, 2006 | 04:49 PM
zex_cool's Avatar
Default Re: Stock B16 and Boosting question. (88crxhfb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote"> on a built stock block ??
i'd go with 100,000,000,000,000,000,000.00 psi
you will have some mad JDM power.
Old Apr 17, 2006 | 04:53 PM
88crxhfb16's Avatar
Default Re: Stock B16 and Boosting question. (zex_cool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zex_cool &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> so, about the same number of times you've beat off to gay ****.
thank you have a nice day
I Have an STD's Avatar
wrenchin'
26.4 psi. thats the limit for a 1.6
Old Apr 17, 2006 | 04:55 PM
88crxhfb16's Avatar
Default Re: Stock B16 and Boosting question. (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">26.4 psi. thats the limit for a 1.6</TD></TR></TABLE>
I only want to run about 17psi. so that would be safe without getting the block sleeved right??
wrenchin'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote"> so, about the same number of times you've beat off to gay ****.
thank you have a nice day</TD></TR></TABLE>
well if u ask a stupid question yer gona get a stupid answer. SEARCH NOOB! there is no "limit" its all in the tune. there are 400+whp 25+psi b16s on stock sleaves and some built B16s blow up on 10 psi. its all in the tune homie, which you would have found out if you SEARCHED
Old Apr 17, 2006 | 05:00 PM
88crxhfb16's Avatar
well if u ask a stupid question yer gona get a stupid answer. SEARCH NOOB! there is no "limit" its all in the tune. there are 400+whp 25+psi b16s on stock sleaves and some built B16s blow up on 10 psi. its all in the tune homie, which you would have found out if you SEARCHED</TD></TR></TABLE>
You are so, full of sh.it. if that were true there would be no need to get a block sleeved. thats bs there is a limit to stock sleeves, thus the reason for getting a block sleeved. and by the way the Search doesnt work.
Old Apr 17, 2006 | 05:23 PM
zex_cool's Avatar
you are an ******* ! ! !
WTF you ask for help and then talk **** ?? good luck ******
Old Apr 17, 2006 | 05:43 PM
wrenchin'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote">You are so, full of sh.it. if that were true there would be no need to get a block sleeved. thats bs there is a limit to stock sleeves, thus the reason for getting a block sleeved. and by the way the Search doesnt work. </TD></TR></TABLE>
um, yer obviously know much less than it seemed. just to let you know, im shotting for 450 whp on B16 i built with stock sleeves on may 4th at evans tuning, stop by and see if it happens
Old Apr 18, 2006 | 01:09 PM
88crxhfb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zex_cool &raquo;</TD></TR><TR><TD CLASS="quote">you are an ******* ! ! !
</TD></TR></TABLE>U stupid ******* PIECE OF ****. what kind of Answer did u give me? I asked a question and U TALKED THE ****. get the story straight butt ******.
Old Apr 18, 2006 | 01:12 PM
88crxhfb16's Avatar
um, yer obviously know much less than it seemed. just to let you know, im shotting for 450 whp on B16 i built with stock sleeves on may 4th at evans tuning, stop by and see if it happens</TD></TR></TABLE>
You know it was a simple question. But it seems everyone on here is to good to answer a question without talking ****. Good luck with the tuning. Hope you meet you goal of 450 whp.
Old Apr 18, 2006 | 01:21 PM
wrenchin'
this is your answer THE ONLY LIMIT IS THE TUNE. if its tuned well,it will make the power and it will hold up, simple as that.
Old Apr 18, 2006 | 02:32 PM
LostSolVTEC's Avatar
the sleeves are not the weak point in the honda motor, it's the stock Piston ringlands. The stock sleeves will hold 600+ hp.
and it's not the PSI you need to worry about, it's how much power the engine is making, PSI is irrelevant. On pump gas mid 400's and then whatever you can push the turbo to on race gas w/o blowing hot air or going past your setup.
Old Apr 18, 2006 | 03:46 PM
88crxhfb16's Avatar
Default Re: Stock B16 and Boosting question. (LostSolVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostSolVTEC &raquo;</TD></TR><TR><TD CLASS="quote">the sleeves are not the weak point in the honda motor, it's the stock Piston ringlands. The stock sleeves will hold 600+ hp.
</TD></TR></TABLE>thanks, just wondering why does everyone insist on getting the block sleeved?? Why should I waste money, I could spend elsewhere (headwork, etc.) I'm not even trying to make more than 400 hp.
Old Apr 18, 2006 | 03:52 PM
Boosted Chemist's Avatar
yeah certain people (jeff evans) make a ton of power on stock blocks. Wiht 400whp goal you dont NEED sleaves but im sure its better to have then not have.
I sleaved my b16a and im shooting for 450-500
Old Apr 18, 2006 | 03:53 PM
turbofunvtec's Avatar
I sleeved mine purely for peace of mind and the ability to go bigger once i get a taste of good boost. I was running 10 PSI on my stock b16 then decided to build it. I hope to run alot more boost and by sleeving i wont be on the raged edge all the time i'm in boost. plus i have room to play if I wanna go bigger
Old Apr 18, 2006 | 05:32 PM
Default Re: Stock B16 and Boosting question. (turbofunvtec)
the main reason for sleeving is for the larger displacement, that's what i'd be aiming for at least.
Old Apr 18, 2006 | 05:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostSolVTEC &raquo;</TD></TR><TR><TD CLASS="quote">the main reason for sleeving is for the larger displacement, that's what i'd be aiming for at least. </TD></TR></TABLE>
oh yeah that too. mines almost a 2.0 now
Old Apr 19, 2006 | 01:30 PM
88crxhfb16's Avatar
so maybe I should spend a little extra and go with the sleeves for future growth. also what bore gives u almost 2.0 and is there still plenty of material left on the sleeves for strength??
Old Apr 19, 2006 | 01:48 PM
Default Re: (88crxhfb16)
84mm and GSR crank, a deck plate and pleanty of strength left
Modified by turbofunvtec at 3:15 PM 4/19/2006
Jun 12, 2009 06:49 PM
c5stunna
11
Oct 28, 2007 01:36 PM
tdark1582
Apr 9, 2007 08:19 PM
cleanasscivic
Oct 5, 2004 12:19 PM
Dasavior
Jan 28, 2004 05:45 PM
