boosting 11:1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NLR »</TD></TR><TR><TD CLASS="quote">yup thicker headgasket .060-.080 should do it</TD></TR></TABLE>
I'm in the middle of waterproofing the block (edit) walls (/edit) in my new shop, epoxying the floors, and running extra 220 breakers for existing welder/air compressor/and future mill/lathe installs. I should have already had the car together already, I lack like $60 in parts and some assembly. Hopefully I'll be terrorizing the streets in it by the New Year. I am teh sux
Have I met you? Because you aren't Dave, Foowee, Bone, and I'm pretty sure you aren't Nick.
No clue about f20x cr's, but as for a thicker hg .070" will lower your comp by ~1cr. Most oem honda hg are .030" in thickness, you will drop your cr by ~.5 for every .020" thicker you go. I personally have a cometic .071" hg, some people swear by cometic, some h8 the hg's. I got the hg long before I knew much better so I figured why not give it a shot. GL.
Run richer, take out more timing than usual, and monitor EGTs because they start climbing when you take out too much timing. When you get her on a dyno, keep it richer, but the ignition tables are easier to dial in, just leave a little more margin for error.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cubish »</TD></TR><TR><TD CLASS="quote">call inlinepro.. they will help you out... a friend of mine used there thick head gasket and ran 18 psi with a gt35e on pump gas and made around 430. stock S2000 motor</TD></TR></TABLE>
i`m not sure what thickness you would use to lower it to 9:1.
as far as InlinePRO i have the benefit of living 15min away.. i`ve always used their headgaskets on stock bottum builds and they have worked great !! the 2.0mm is used to make 9:1 on the b18c1(USDM). i`ve run 15psi on a stock motor for over a almost 6 months before selling the car and never had compression problems or problems blowing smoke out of the exhaust.. the only thing i would say to do is after installing a head gasket is, run the motor (preferably tuned) drive it until it heats up and boost it. make a few good (hard) passes then go back and torque the head back down (do not remove the head, only re-torque it. )
i think i torqued it down to something like 64ftlbs.
mike1114
Jul 2, 2003 01:16 PM
