boosted LS owners... a few ?'s
Old Jun 19, 2003 | 06:16 AM
2lowintegra's Avatar
Default boosted LS owners... a few ?'s
please post what turbo are you using (including trim specs and a/r) and where in the rpm band you start spooling and when you reach full boost....
Old Jun 19, 2003 | 08:38 AM
JM Performance's Avatar
Default Re: boosted LS owners... a few ?'s (2lowintegra)
T04b/t3 comp: s-3 turb: .48 stage II
Spools quick, full boost by 3000 but top end falls off. Good for around town, but not so much for drag or max power.
Old Jun 19, 2003 | 09:00 AM
X2BOARD's Avatar
Default Re: boosted LS owners... a few ?'s (00SilverLS)
Straight t3, .48 a/r
With 2.5" to stock Gsr muffler, full spool by 3500 rpm. Great around town driving/street. Strong mid range, good topend... but runs out of breath at the top.
The car was a beast out of the hole.
X2
Old Jun 19, 2003 | 09:20 AM
Default Re: boosted LS owners... a few ?'s (X2BOARD)
nice, nice.... keep em coming guys... i am putting together a kit and am looking for experiences/opinions on turbo size/specs!!
Old Jun 19, 2003 | 09:26 AM
CheezeFrog's Avatar
T3/60-1. .63 AR, Stage 5 wheel. Crower 403T cams. Pulls like a raped ape from about 6k up to 9k RPM's. 430hp@22psi & 110oct race gas. 340hp@17psi & 93oct pump.
Old Jun 19, 2003 | 09:29 AM
Default Re: boosted LS owners... a few ?'s (CheezeFrog)
^ holy ****...... nice... but that set up is way too hardcore for me.... i won't be raising redline or anything.... nor will i be going with turbo cams..... this is a street car that might see the odd drag
Old Jun 19, 2003 | 09:56 AM
Cyphear's Avatar
If you want to have the boost kick in early and dont plan on running much, go with a T3, or even a T25(very small). If you want to set it up for drag racing go with a t3/t4.
Old Jun 19, 2003 | 10:08 AM
Default Re: boosted LS owners... a few ?'s (Cyphear)
^ yeah i am thinking about t3/t04e 50 trim, .63 a/r.... but where would this start to spool and where would it reach full boost on an LS??.... ( i don't want something that's going to lag until like 3900rmp)... i'd like something that starts around 3000rpm but doesn't run out of steam before redline...
Old Jun 19, 2003 | 10:26 AM
SupaTeg's Avatar
Don't know the trim but it is a TD05H-18G. Start spoolng at 2500 rpm and 3500 full boost
Old Jun 19, 2003 | 11:05 AM
shermanyang's Avatar
Default Re: boosted LS owners... a few ?'s (SupaTeg)
8.8:1 compression pistons...t3/t04e .63 turbine .60 compressor .57 trim....i spool at 3-3.4k and get full boost at 4.5-6k depending on what gear i'm in. keeps pulling till the end...
Old Jun 19, 2003 | 11:45 AM
turbospool's Avatar
Default Re: boosted LS owners... a few ?'s (shermanyang)
stock long block, precision t3/t04e .60 trim on compressor and .63 turbine, full boost around 4200.
Old Jun 19, 2003 | 12:07 PM
DIRep972's Avatar
Smarter than you
Default Re: boosted LS owners... a few ?'s (turbospool)
stock LS. stage 3-.63 T3/T04e 57 trim. starts to spool @ 2500. 7lbs @ 3700. 13lbs @ 4400. Pulls hard from 5k-6500 and then falls off till I shift @ 7500. Im pretty happy w/ it 230tq and 270hp was good enough for 12's.
Old Jun 19, 2003 | 09:21 PM
X2BOARD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lowintegra &raquo;</TD></TR><TR><TD CLASS="quote">i'd like something that starts around 3000rpm but doesn't run out of steam before redline... </TD></TR></TABLE>
A T3 is basically what you're looking for... the LS redline is not so high that she'll run out of steam.... heh... there's a reason it's used on so many production turbo cars.
X2
Old Jun 20, 2003 | 06:32 AM
thanx guys.... anyone else!
Old Jun 21, 2003 | 12:34 PM
anyone else??
i am looking to start spooling around 3200 rpm on my stock LS motor... what t3/t04e would do this? (what trim and a/r?)
Wyatt87
Aug 5, 2010 12:59 PM
Nonsteezy
Oct 19, 2004 02:46 PM
f1 vtec
Sep 10, 2004 09:40 AM
CRiX
Jan 23, 2003 08:57 PM
DRAGLS
Apr 9, 2002 04:37 PM
