boosted k20a2 having issues
Okay well to start off the car is a 03 RSX Type S with a full greddy kit installed injectors and all.. No problem with the turbo kit. There is k pro for the car which is in it car. Timing reads @ -4 at idle. Bogs when you give it fuel and doesn't change when you lean it out ither. Checked timing it was TDC( would fiqure timing would be perfect because car ran perfectly fine before the turbo never have issue or a check engine light). Just can't fiqure it out called hondata and ask a few other guys around no one came seem to fiqure it out. Please need help the car belongs to a buddy.
Never ran in to this issue with any other boosted k20's or NA K20's and ive tuned over at least 10. Need help ASAP any little info helps.
