Stroking or boring?
Old Nov 3, 2002 | 12:55 PM
done's Avatar
Default Stroking or boring?
Which would be better? Stroking the motor to 2.0litr or borning to 2.0 litr....
Give pros and cons of both...
Im thinking stroking would effect rod ratio alot...
Thanx guys,
Jordo
Old Nov 4, 2002 | 06:08 AM
done's Avatar
Default Re: Stroking or boring? (Jordo)
up we go
Old Nov 4, 2002 | 06:12 AM
Eric R's Avatar
I think if you stroke, you have more torque and a lil less rpm.
If you bore, keep the rpm and has more power. IMO.
Old Nov 4, 2002 | 06:15 AM
Eric R's Avatar
...also, if you bore, you keep the same rods and need to buy pistons.
if you stroke, might keep the same pistons and buy crank and longer rods.
Whichever is in your budget.
[Modified by Tweety R, 7:17 AM 11/4/2002]
Old Nov 4, 2002 | 06:18 AM
done's Avatar
Default Re: Stroking or boring? (Tweety R)
Im thinking a 84.5mm bore would be best
Old Nov 4, 2002 | 06:26 AM
Eric R's Avatar
Old Nov 4, 2002 | 08:07 AM
eviltwin's Avatar
with a 89mm stroke.
cant go wrong with that
Old Nov 4, 2002 | 08:15 AM
done's Avatar
Default Re: Stroking or boring? (eviltwin)
what will i need for a 89 stroke? new rods and pistons and crank.. who makes a crank that is 89 stroke..
Old Nov 4, 2002 | 08:20 AM
Rob :190:'s Avatar
what happened to the turbo? mad more show points, thats the fizzle.......
Old Nov 4, 2002 | 08:24 AM
onyx00's Avatar
Default Re: Stroking or boring? (Rob :190:)
I'm more of a strokin' man myself
Old Nov 4, 2002 | 08:25 AM
eviltwin's Avatar
ls crank.
ls rods
84.5 mm pistons
89mm x 84.5mm= 2.0L
damn worth it.
[Modified by eviltwin, 5:28 PM 11/4/2002]
Old Nov 4, 2002 | 08:50 AM
sackdz's Avatar
"Stroking" just sounds so much more exciting than "boring."
Stroke it
Old Nov 4, 2002 | 12:01 PM
Spike2's Avatar
I was under the impression that if you sleeved a gsr block to 84 mm, it would be a ~2.0L
Is this not true unless you get an LS crank & rods?
Old Nov 4, 2002 | 12:03 PM
Reid's Avatar
Global Moderator
Default Re: Stroking or boring? (Spike2)
Why?
Old Nov 4, 2002 | 02:59 PM
done's Avatar
this is informative post, purely imformative ..
but could you imagine bored/stroke to 2.0 while under Pressure
Old Nov 4, 2002 | 03:01 PM
done's Avatar
compare ls crank to type r crank
I know type r crank is knifved edged and balanced. how is ls crank?
That would be interesting, getting ls crank edged and balanced and mirco polished.. and buying aftermarket ls rods
might be cost effishion also
I cant spell
Old Nov 4, 2002 | 03:07 PM
done's Avatar
84.5 X 84.5 X 87.2 X .7854 X 4 X .001 = 1956cc not stroked
84.5 X 84.5 X 89 X .7854 X 4 X .001 = 1996.43cc stroked
now for the 84mm thing
84 x 84 x 87.2 x .7854 x 4 x .001 = 1932.97cc two liters you be the judge...
Old Nov 4, 2002 | 03:10 PM
ryu12341's Avatar
i was thinking of doing the same thing also. I would love to have a 2 liter boosted motor. So it would take ls crank, rods, and 84.5 mm pistons then, with a resleeved block?
Old Nov 4, 2002 | 03:16 PM
done's Avatar
Default Re: Stroking or boring? (ryu12341)
yess...
I really really really want someone to touch this topic..
"compare ls crank to type r crank
I cant spell "
If its possible to make a ls crank, just as good as a type r.. while keeping the displacement
Old Nov 4, 2002 | 03:27 PM
fortynineR's Avatar
type r cranks are not knife edged....they are counterweighted. you can balance an ls crank but u cannot counterweight it...
Old Nov 4, 2002 | 03:32 PM
done's Avatar
Default Re: Stroking or boring? (fortynineR)
whast the difference counterweight and balance??
Im told R cranks hold power in mid range comparable to ls cranks... ive seen some dynos.. i think they were importbuilders..
Are you sure they are knived edge.. let me find that diagram that said that...
Old Nov 4, 2002 | 03:40 PM
jond's Avatar
I'm not sure with imports, but with V8s, you can only bore out .060. I bored my 289 out that much, and its not much difference. I think around 10 cubic inches for me. However if I got a stroker kit, I could add around 90 cubic inches!!!
Old Nov 4, 2002 | 03:44 PM
fortynineR's Avatar
balancing is basically balancing... counterwieghts add material to the crank to achieve a better balance for higher reving motors.. knife edging is removing wieight from the crank for faster reving motors... i believe counterwiegted cranks (itr) hold more power on top while knife edge may make u lose power on top but it will make ur motor rev up faster...
Old Nov 4, 2002 | 03:48 PM
done's Avatar
in your total opinion
What do you think would be best?
to make a ls crank comparable to a type r crank...
If the motor will be boosted, im thinking knife edged wont help....
Are crower cranks worth a damn? and any other companys make cranks?
Old Nov 4, 2002 | 03:50 PM
-Whitey-'s Avatar
heh by the title of this thread i thought you werte asking what you should call masturbating ....then i thought how would he get bored?...ohh wait he must be gay but then i realized i wasnt in the members only forum and i was brought back to reality.
