The Boosted D Lives
Old Apr 14, 2004 | 02:19 PM
pornstarSR's Avatar
Default The Boosted D Lives
So after 3 years and to many hours to count. its done. finished fab work monday night. and saw that my Rear subframe was ripped out(damn swaybar)
so after welding my subframe, Install went pretty well.
heres pics
ok heres the specs- boosting 5-psi
D16y7
stock bore endyne rollerwave 9.5:1 pistons(thermal coated)
Pauter Rods
Ferrea valves(thermal coated) and valve springs
ported and polished head(thermal coated)
arp head bolts
arp main cap bolts
micropolished crank
y8 intake manifold
y8 tranny
Hks gt2510 ball bearing turbo(thermal coated, and slightly ported housings)
revhard manifold, modified for t25
custom 2 1/4 piping
hks ssq blow off
custom back door intercooler(i know its a baby one)
custom 3 inch downpipe
apt vband t25 outlet
vortech fmu w 12:1 disc(yeah i know crap)
missing link
flaminco T feed line(4an, i hks has a restrictor banjo fitting so i had too, no smoke. so its good)
HKS magic mushroom intake, but with black element
ok so this is it. maybe somethings i forgot.
i did all the piping work myself(getting used to using a TIG was hard)
thanks to everyone for the help
Modified by pornstarSR at 6:12 AM 4/15/2004
Modified by pornstarSR at 6:46 AM 4/15/2004
Old Apr 14, 2004 | 02:30 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: The Boosted D Lives (pornstarSR)
Took ya long enough, ****.
I've been reading about your setup since I was 18 - now I'm almost 21.
Old Apr 14, 2004 | 03:13 PM
ITSTOCK's Avatar
Get some better fuel management and run 14 psi!!!
Old Apr 14, 2004 | 03:32 PM
teal EJ1's Avatar
Default Re: The Boosted D Lives (ITSTOCK)
NOICE!
Old Apr 14, 2004 | 04:05 PM
Pfieff's Avatar
Def. pick up hondata and call it a day.
Old Apr 14, 2004 | 05:10 PM
youngkow's Avatar
Nice! What sleeves are you using?
Old Apr 14, 2004 | 06:41 PM
sohcT's Avatar
y7 excellent
Old Apr 14, 2004 | 09:11 PM
pornstarSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">Took ya long enough, ****.
I've been reading about your setup since I was 18 - now I'm almost 21. </TD></TR></TABLE>
thats scares me.....but thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngkow &raquo;</TD></TR><TR><TD CLASS="quote">Nice! What sleeves are you using? </TD></TR></TABLE>
stock bore
stock sleeves...we decided not to sleeve at the time of the build
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog &raquo;</TD></TR><TR><TD CLASS="quote">Def. pick up hondata and call it a day.</TD></TR></TABLE>
yeah im planning on running aem ems...but i needed to boost it...so i threw together the fmu and missing link... its only 5 psi so it should be fine for right now.
but im surprised 5 psi is pretty quick. and its steady 5psi
Old Apr 15, 2004 | 12:26 AM
psileepR's Avatar
New User
Default Re: The Boosted D Lives (boostincoupe)
just what i was thinking ... glad to see its finally boosted and running
Old Apr 15, 2004 | 01:12 AM
pornstarSR's Avatar
Default Re: The Boosted D Lives (psileepR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psileepR &raquo;</TD></TR><TR><TD CLASS="quote">
just what i was thinking ... glad to see its finally boosted and running </TD></TR></TABLE>
dude you guys are scareing me...i didnt knwo this many people knew me.
well on the topic of running...its got an issue
i posted it in a seperate thread. but ill say it here to, it has a nice buck and hesitation at medium throttle and full...but the boost and spool are steady and smooth... i think its either missing link, or plugs.
Old Apr 15, 2004 | 02:06 AM
Maintenance's Avatar
looks good man.
[QUOTE=pornstarSR]
QUOTE]
maybe its your screen name? j/p
What rpm did the hestation occured at? Do you have a wideband or an a/f?
Old Apr 15, 2004 | 02:34 AM
ATS*Mark's Avatar
OG triple OG
Default Re: The Boosted D Lives (racerxfear)
what are your plugs gapped to? are they stock plugs , or colder....you should be running at least 1 step colder plugs and at least a .30 gap
mine are 2 steps colder at .28
Old Apr 15, 2004 | 02:40 AM
pornstarSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxfear &raquo;</TD></TR><TR><TD CLASS="quote">looks good man.
doesnt have a specific rpm.. its irratic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">what are your plugs gapped to? are they stock plugs , or colder....you should be running at least 1 step colder plugs and at least a .30 gap
mine are 2 steps colder at .28</TD></TR></TABLE>
stock plugs...im gona change them tomarrow
Old Apr 15, 2004 | 02:47 AM
ATS*Mark's Avatar
OG triple OG
do the plugs thats the first step
Old Apr 15, 2004 | 10:42 AM
pornstarSR's Avatar
Default Re: The Boosted D Lives (Hella_JDM)
bkr6es 11 gapped to .30?
sound right for plug
Old Apr 15, 2004 | 10:48 AM
Smokinsax's Avatar
The Boot
way to get it done right! BTW: where did you get that WG block off plate?
Old Apr 15, 2004 | 02:35 PM
pornstarSR's Avatar
Default Re: (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">way to get it done right! BTW: where did you get that WG block off plate?</TD></TR></TABLE>
Atpturbo.com
i got lots of parts from them...they got good stuff...
thats where i got the flanged adaptor to run my 3 inch V band downpipe
heres the link
http://www.atpturbo.com/Mercha...e=FLS
Old Apr 15, 2004 | 02:37 PM
pornstarSR's Avatar
Default Re: (pornstarSR)
oh yeah and i lightly cleaned the missing link and the bucking and hesitation is pretty much gone..
changing plus right now...
thanks guys
im doing zfr6j-11 and regapping them...these are the plugs the motor builder gave me....i forgot i had them....im getting some other ones tomarrow too...
Old Apr 15, 2004 | 02:40 PM
.dave's Avatar
i HAS questions ?
That looks sweet man. I can't wait to get my turbo D running.
Old Apr 15, 2004 | 04:45 PM
RyanEJ8's Avatar
Nice setup. Can't wait to see the kind of power you will make when you get the AEM EMS and up the boost.
Old Apr 15, 2004 | 05:35 PM
danl's Avatar
Banned
Default Re: The Boosted D Lives (RyanCivic2000)
Chip an OBD1 computer to boost and have much better control over things for not much more cost. PM me if you need pointed in the right direction.
Old Apr 15, 2004 | 05:47 PM
ATS*Mark's Avatar
OG triple OG
Default Re: The Boosted D Lives (danl)
if it doesnt help try gapping to .28 , most people say that even .30 is too much
Old Apr 15, 2004 | 07:53 PM
fsp31's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstarSR &raquo;</TD></TR><TR><TD CLASS="quote">bkr6es 11 gapped to .30?
sound right for plug</TD></TR></TABLE>
I've been using the ngk bcpr7's for a 18 months. I'm really happy with them.
Old Apr 16, 2004 | 12:16 AM
pornstarSR's Avatar
well
i swapped the plugs. to the zfr6j-11s regapped to .32, didnt have a sparkplug gapper gauge so used feeler gauges(2 together to be exact)
cleaned the missing link really well
and advanced the timing to 10 degrees
then i tightened the wastegate acutator arm, becaue the flapper valve is rattling... not a good idea....it then boosted to 7psi...i dont want to run that just yet...
so stopped by sears, borrowed some tools.. put it back...5psi again...still rattles too
the hesitating and bucking its mostly gone...but its still some what there...only slightly though...
Old Apr 16, 2004 | 02:53 AM
ATS*Mark's Avatar
OG triple OG
could be tuning issues......
