Boosted Crower 404's?
Old Jun 16, 2007 | 08:34 AM
  #26
alpha's Avatar
Default Re: (IBleedJDM)
The setup I tuned I left the rev limiter at 8200RPM. I did this because of the crappy LS transmission. Leaving the rev limiter at anything less than 8200RPM caused the car to fall on it's face from 2nd to 3rd shift. Torque was falling off by 6300RPM/6400RPM but horsepower was still going up at 7500RPM. This was with cam gears at 0* and a street tune jumping on the dyno at a dyno day. Never got to finish tuning the setup. Had a cracked One-Fabrication exhaust manifold, slipping RPS clutch, etc. Decided to go LS/VTEC with a larger turbo, better exhaust manifold, etc.
Old Jun 16, 2007 | 08:54 AM
  #27
mrbsponge's Avatar
I tuned a buddys car with a 60-1 turbonetics t3t4, stock bottom end, and a set of crower 404s, and the car made 335@13psi on a stock 1 bar map sensor.
when it hit 7K it felt and sounded like the car had vtec, it was wild.
if you use some sort of management you can almost eliminate the lope of the cams with fuel and timing, we were using hondata and i adjusted the IACV and mod'd the timing to made it idle smooth, damn near like stock
later on we added a 3 bar map turned the boost up and made 390@16psi same turbo and set up
Old Jun 16, 2007 | 09:17 AM
  #28
tannerLSt's Avatar
ME LOVE U LONG TIME
i had a 85mm bottom end with crower everything in the head with 404's..... made 403whp and 342wtq on 19psi on 93 octane... idle was pretty smooth, smoother than i thought it would be. this was on a SC61 e housing with .63 exhaust side...
think i reved it to 8k
Old Jun 16, 2007 | 10:41 PM
  #29
TopEndTuner's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jun 16, 2007 | 11:05 PM
  #30
bigbadboy's Avatar
is messing with the cam timing good to do on the dyno with these cams or is it not worth it?? anyone have any vids of idle with these cams. i love lopy idles
Old Jun 17, 2007 | 08:19 AM
  #31
SPOOLINmatt's Avatar
Default Re: (bigbadboy)
leave it to us import boys to have a lopy cam idle like stock.
hehe
Old Jun 17, 2007 | 08:43 AM
  #32
alpha's Avatar
Default Re: (SPOOLINmatt)
Here is a couple. I wish I had taken more. Didnt know there would be a lot of interest, hah
Driving around. Idle. Decel
Stupid old street race with a 2G DSM. The DSM also had a GT30R on it. I think 18lbs - 20lbs. The hatch was on 12lbs - 14lbs if I remember correctly. At the end something happened with the MAP sensor causing the car to go pig rich
Old Jun 17, 2007 | 12:28 PM
  #33
http://www.youtube.com/watch?v=faBSXJGu4ek
Sounds like a friggin Harley
Old Jun 17, 2007 | 06:49 PM
  #34
gearhead313's Avatar
25 Year Member
I still like my old idle with the 404's
http://media.putfile.com/itb-hatch-idle
Old Jun 17, 2007 | 07:01 PM
  #35
Default Re: (gearhead313)
God I love ITB's! I want people to hear that and then a blow off later!
Old Jun 18, 2007 | 05:40 AM
  #36
25 Year Member
If i cant sell that motor, im very tempted to change the pistons and bolt a little T58 I have laying around on it.
Old Jun 18, 2007 | 09:43 PM
  #37
Do it!!! I have become a boost addict
Old Jun 19, 2007 | 09:36 PM
  #38
Anybody had one of these break I read a thread and I'm getting a bit nervous about it.
Old Jun 25, 2007 | 07:35 PM
  #39
Do you think Cryo treating them before use might help stop them from breaking?
Old Jun 25, 2007 | 09:42 PM
  #40
tony413's Avatar
the breakage issue should be fixed by now but i recommend cyro treating any part over heat treating
Old Jun 25, 2007 | 09:52 PM
  #41
Default Re: (tony413)
Any particular business in general or just any?
Old Jun 26, 2007 | 01:20 PM
  #42
tony413's Avatar
yes i'll post the company i used once i find the website again
Old Jun 26, 2007 | 02:28 PM
  #43
alpha's Avatar
The older Crower VTEC camshafts use to snap. I was witness to this a long time ago. The non-vtec camshafts are fine
Old Jun 26, 2007 | 03:37 PM
  #44
agrn93ls's Avatar
Default Re: Boosted Crower 404's? (IBleedJDM)
subscribing
Old Jun 26, 2007 | 05:31 PM
  #45
Default Re: (alpha)
So it was the older Vtec cams? The more I read the more I seemed to only see this in Vtec motors I just assumed it was happening to all of their cams
Old Aug 20, 2007 | 10:37 PM
  #46
Default Re: (TopEndTuner)
At 8000 + RPM what is the fail point? I am doing everything I can to get it to 8 grand safely. Eagle rods w/ 3/8" rod bolts, Dual Valve Springs, Chromoly retainers, and Ferrea valves, think this will withstand 8 grand and still be making power with the 404' and 15 lbs? By the way its my thread so I am resurrecting it.
Old Aug 21, 2007 | 06:52 PM
  #47
bump
Old Aug 21, 2007 | 07:11 PM
  #48
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TopEndTuner &raquo;</TD></TR><TR><TD CLASS="quote">Any particular business in general or just any?</TD></TR></TABLE>
i reminder you asking about this and this is a good company to use
http://www.ffwdconnection.com/minus330.shtml
Old Aug 21, 2007 | 08:33 PM
  #49
Sweet thanks for the tip. Anybody have anything to say about revving these things to 8K? I just want to know the sweet spot with boost. I've checked the LST thread but it only tells setups not powerbands.
Old Aug 21, 2007 | 08:44 PM
  #50
bigbadboy's Avatar
if ur upgrading your rods then u should be fine with that. everything should be safe.
