Boosted built h22
Old Oct 27, 2009 | 10:40 AM
mozzandherb's Avatar
Honda-Tech Titanium Member
Default Boosted built h22
Just wondering how this setup sounds. I'm looking to reach at least 400whp. I will be racing it quite a bit at the drags. I know sleeving the block would be better, but I really am considering this build. I just has some concern over the 10:1 compression with the pistons...is that too high. The car will be running at lower boost as my dd, but will turn up the boost for the track. Any thoughts besides "you should sleeve the block"...thanks. And I have read through the entire Mahle thread and haven't really seen a lot of negative feedback, that's another reason why I am considering this build.
Old Oct 27, 2009 | 10:57 AM
H.Veras's Avatar
Default Re: Boosted built h22
So what is the set up? I guess you will be running Mahle pistons since you mentioned them, but that is the only thing you mentioned. What else will you be using?
Old Oct 27, 2009 | 02:46 PM
TweakIntheCO's Avatar
Why are you afraid of 10:1?
Old Oct 27, 2009 | 02:52 PM
d112crzy's Avatar
Mahle makes 9:1 compression pistons. Either way, 10:1 is far from high compression and for only 400whp it's nothing to worry about as long as you have good fuel.
Old Oct 27, 2009 | 07:21 PM
lol...my bad...here's the rest
skunk2 pro series stage 1 camshafts
skunk2 pro series adjustable cam gears
skunk2 valves
skunk2 valve springs
skunk2 titanium retainers
skunk2 intake manifold
skunk2 68mm throttle body
eagle h beam rods
mahle gold series 10:1 pistons
cometic head gasket
kaizen speed balance shaft eliminator kit
acl main bearings
acl rod bearings
arp head studs
arp main studs
moroso oil pan
moroso oil pick up
hondata intake manifold gasket
micro polished and balanced crank
3 angle valve job
aem fuel rail
rc engineering 750 cc injectors
all new honda seals and gaskets
new jdm distributor
nology hotwires
custom painted valve cover w/ cutouts for cam gears
h23 manual tensioner conversion
new honda water pump
new honda timing belt
I will probably keep my t3/to4e 60-1 turbo that I am currently using.
Old Oct 28, 2009 | 05:45 AM
H.Veras's Avatar
You definetly will be able to reach that goal of 400whp. However, keep in mind that our sleeves are not the best for boost, so a good tune will be necessary to keep that motor alive.
Old Oct 28, 2009 | 06:06 AM
1fastlude1's Avatar
you said your currently boosted whats the setup right now? what ems
Old Oct 28, 2009 | 06:21 AM
Currently it's a stock h22, running 8 psi with EcTune.
Old Oct 28, 2009 | 06:59 AM
1fastlude1's Avatar
the mahle pistons are good i ran the golds for a awhile i finally sleeved the block but i used the sleeved version from mahle, i would just save some money get it sleeved so your done and have the peice of mind i got mine sleeved from jg for 850 maybe get hondata get a good tune, up the boost a little and wait i know it sucks but its worth it your gona have all that money in it you dont want any thing to happen.
Old Oct 28, 2009 | 03:56 PM
purpleh22's Avatar
You should be fine. Run the 9:1s if you want added insurance for running pump gas. You won't loose anything by dropping the CR. FRM (H22) sleeves can take as much stress as iron sleeves. The big concern for an H22 is the ring lands on a stock piston. It's important to have someone do the work (honing) on the H22, that knows what they are doing with FRM sleeves and that they have the proper hones. The cylinders should look smooth and not crosshatched when they are completed.
Old Oct 28, 2009 | 06:33 PM
d112crzy's Avatar
1 point in compression makes a bit of a difference. See this article for example.
http://forums.evans-tuning.com/viewt...hp?f=15&t=1612
That 15whp could have been made up with about 2-3psi more on the 9:1 setup.
Old Oct 29, 2009 | 09:45 AM
purpleh22's Avatar
Or about 1 psi.
Old Oct 29, 2009 | 02:51 PM
trickeng's Avatar
H22 sleeves are far stronger than Bseries sleeves. You shouldn't have to worry about them only running 400whp. Keep in mind you can also run .125wall (stock .093wall) repair sleeves for a little more strength and the ability to run what ever forged piston you want.
Old Oct 29, 2009 | 04:11 PM
d112crzy's Avatar
Or about 1 psi.
WHen's the last time you seen a 15whp gain off of 1psi? It's different with every turbo and setup, but it isn't very common in a lot of builds because people don't usually build very efficient systems.
Old Nov 2, 2009 | 06:54 AM
purpleh22's Avatar
Probably last week.
BADxKARMAx
Oct 13, 2012 09:25 PM
antballs420
Aug 21, 2005 09:51 AM
brad_prelude
Jan 18, 2005 02:44 PM
djnikko
Sep 30, 2004 12:21 AM
