BOOSTED B18C5 COMPLETE BUILD DAILY DRIVER 400HP?
Old 04-27-2012, 12:07 PM
EK9
Dc4LsTeG's Avatar
Default BOOSTED B18C5 COMPLETE BUILD DAILY DRIVER 400HP?
Alright let me start off by saying yes I already have a build thread in the appearance section for the car, I wanted to post a thread in here to get input and info from you FI guys on my build and to post questions here if I have them and get some answers.
Build thread for car
https://honda-tech.com/forums/appearance-build-threads-122/dc4lstegs-build-thread-real-98-ek9-ctr-lots-pics-3019427/
So Im 19 and this is my first engine/turbo build. I had the B18C5 NA and it was pretty much stock besides bolt ons, being dumb and not researching first I decided to throw on a turbo kit and it pretty much cracked all 4 piston ringlands the first time I tried to drive it So after that happend I decided that I need to rebuild my complete motor and do it right this time.
Goals/Plans:
350-400 hp (until I can upgrade injectors and turbo, then maybe 450+hp??)
Car will be a DD but hopefully taken to the track quite a bit.
I want traction!
Super clean set up thats BUILT THE RIGHT WAY
Hopefully getting the block sleeved in the future
Set Up(As of now):
Engine:
98 B18c5(everything including clutch/flywheel balanced within .02gs)
81.5 supertech pistons 9.9:1
Eagle Rods
Stock ITR crank(balanced and micropolished)
OEM oil/water pump
Gates kevlar timing belt
Head:
ITR cams w/ BC cam gears
ferrea 5000 series valves(4-5 angle valve job)
supertech bronze valve guides
ITR dual valvesprings(hope to upgrade soon)
p73 spring style lmas
Stock ITR/p73 Intake mani/tb
arp headstuds
Turbo Kit:
Turbonetics t3/t4 60 trim(until I can upgrade)
Peakboost Ramhorn mani
3" downpipe(buddy club spec 2 catback)
Turbosmart 38mm wastegate(open dumptube, non-recirculating)
2 1/2" intercooler piping
Greddy bov
Greddy CARB legal stamps
Fuel System:
Walbro 255lph pump
Delphi 525cc injectors(Until I can afford ID1000s)
Stock fuel rail/fpr/fuel filter
Trans:
01 gsr trans
CC stg4 clutch
xtd 8lb flywheel
EMS:
Hondata S300v2 w/ BBG
Innovate MTX-L wideband
Hondata 4 bar map
As said this car will mainly be a DD and tuned on 91oct.
Where Im at right now in the build
Just got the block back from machine shop from being fully balanced, but cant do my bearing measurements yet because the digital dial bore gauge I ordered
over a month ago still hasnt got here. Then just waiting to get my head back from the machine shop which is having a 4-5 angle valve job done to it, and getting the valve guides replaced on it. Should be done next week.
As said I want any comments/suggestions/criticism/anything anyone wants to say.
Now on to the pics!
EK9
Dc4LsTeG's Avatar
Default Re: BOOSTED B18C5 COMPLETE BUILD DAILY DRIVER 400HP?
Old 04-27-2012, 12:08 PM
EK9
Dc4LsTeG's Avatar
EK9
Dc4LsTeG's Avatar
And the car its all going on 98 CIVIC TYPE R(yes its real)
Old 04-27-2012, 12:25 PM
phaphon's Avatar
Nice. We all make mistake. Looks like your on the right track .
Old 04-27-2012, 02:39 PM
EK9
Dc4LsTeG's Avatar
Thanks. Yea it was a pretty costly mistake
Old 04-27-2012, 03:04 PM
phaphon's Avatar
What's that thing under the oil sandwhich plate ? Man nice car
Old 04-27-2012, 03:12 PM
EK9
Dc4LsTeG's Avatar
My ring filer for gapping ths rings. That one I ordered from summit and it works great. Thanks again
Old 04-27-2012, 03:53 PM
Meighty7's Avatar
Looks legit, where did you get your guages; just curious
Old 04-27-2012, 04:20 PM
EK9
Dc4LsTeG's Avatar
Thanks. Wideband I got from Phearable.net with the hondata. And my oil pressure and boost gauge I got off of Ebay
Old 04-27-2012, 04:47 PM
Whiterice-gsr's Avatar
ya dude looks like u are on your way to making a nice *** build, the only thing i see so far is your couplers, i cant tell from that pic but if they are just the rubber ones they will split under boost, if they have thread in them then they are 3 or 4 ply which will be fine. i bought all vibrant ones because mine split.
Old 04-27-2012, 04:50 PM
EK9
Dc4LsTeG's Avatar
Yea I plan on replacing the couplers and clamps before it goes back together
Anyone have any recommendations for clamps?
Old 04-27-2012, 05:05 PM
im still using my reg old worm clamps wich i know are crap but they havent failed me yet, the T bar ones are the best, very very strong.
Old 04-27-2012, 05:08 PM
Freshdot's Avatar
sick build man, nice job at 19
Old 04-27-2012, 05:12 PM
EK9
Dc4LsTeG's Avatar
The Ebay ones? I broke 2 of them over tightening them the first time
Thank you
Old 04-27-2012, 05:57 PM
mar778c's Avatar
Those 5000 series valves are not so good for a turbo application.
Old 04-27-2012, 06:27 PM
lol ya thats the trick not to do that.
Old 04-27-2012, 06:31 PM
EK9
Dc4LsTeG's Avatar
Am I going to have problems with them? Whats wrong with them?
Old 04-27-2012, 08:40 PM
bobmugen's Avatar
wow those bc cam gears are coming real close to looking like swastikas haha
Old 04-27-2012, 09:46 PM
EK9
Dc4LsTeG's Avatar
Lol that's what I thought. They are different then the ones pictured when I bought them and they wouldn't return them
Old 04-27-2012, 11:42 PM
rich7777's Avatar
I think this will be a great build. You've chose sensible parts for a sensible goal. Good luck with it man. I hope all works out well.
Old 04-28-2012, 05:09 AM
mar778c's Avatar
Hopefully, you won't have problems with them. Flat face valves are heavy and run pretty hot in boosted applications. The problems tend to be snapped valve stems and less resistance to pre-ignition.
Old 04-28-2012, 05:41 AM
rich7777's Avatar
I'd just call Ferrea and see what they say.
Old 04-28-2012, 05:52 AM
mar778c's Avatar
Rather than calling the manufacturer, how about someone who has no vested interest in the product like say a head porter. Seriously, you think they are going to say nah don't use our product.
Old 04-28-2012, 06:28 AM
rich7777's Avatar
Actually yes i do as I've been in contact with them a few times now and they've gave me a non biased answer. I could understand if we were on about blox or some shitty eBay company. But Ferrea... no way...
Quick Reply: BOOSTED B18C5 COMPLETE BUILD DAILY DRIVER 400HP?
