boosted b18b, very low vacuum
Old Aug 27, 2012 | 12:24 PM
bradysyde's Avatar
Default boosted b18b, very low vacuum
I have a fully built b18b, wisecos, eagle rods, supertech valve springs, JG 303 cams.
I'm trying to get my car on the dyno but I cannot pull more than 10 inhg at idle. My intake cam was a tooth off at one point but I quadruple checked it and it seems to be on point now. When my buddy first got the basemap tweaked out I did a compression test and it was 170 across the board. I will be doing a compression test tomorrow as when I took of the VC today the gasket stretched. At this point i'm not sure what it could be. When my springs were installed he checked my valves and they were all okay.
bradysyde's Avatar
Default Re: boosted b18b, very low vacuum
would having my intake cam a tooth off cause THAT low of vacuum. They are somewhat larger cams but people still pull around 20 inHG with them.
Old Aug 27, 2012 | 01:16 PM
rich7777's Avatar
Maybe, either way If the cam timing is out you're waisting your time. If it was out originally then it will still be out now.
Old Aug 27, 2012 | 01:18 PM
bradysyde's Avatar
Cam timing.. so your saying I need cam gears? Even though they're drop in cams?
Old Aug 27, 2012 | 01:26 PM
got-vtec?'s Avatar
idk how much mileage is on your rebuild, but my vacuum was pretty low too on my rebuild until i drove it around for a bit.
Old Aug 27, 2012 | 01:27 PM
bradysyde's Avatar
Just trying to get it to idle before break in on Dyno
Old Aug 27, 2012 | 01:31 PM
rich7777's Avatar
No, I'm saying if it was a tooth out in the first place it still will be a tooth out. It won't just fix it's self... you need to take the crank pulley off and check that way.
Also if they give you a "timing sheet" with those cams they need to be degreed. If they didn't I'd call them to confirm they're a drop in cam. Personally, I don't think there's such thing as a drop in cam myself...
Old Aug 27, 2012 | 01:40 PM
wantboost's Avatar
Who is Mr Robot?
^what he said.
if you put the new cams in and found out it was a tooth off after the install and you didn't do anything to fix it... its still a tooth off.
and I degree every cam no matter what.. I even degreed the cam we put in the ls7... and its a katech cam... always check things like that to be sure they are installed correctly
Old Aug 27, 2012 | 02:05 PM
bradysyde's Avatar
8 have reset the timing since that. Crank, and cams ALL line up.
Old Aug 27, 2012 | 07:43 PM
Muckman's Avatar
Moderator in Chief
I would break it in with an OEM cam. You dont want to deal with tuning issues when you should be seating the rings.
Old Aug 27, 2012 | 10:05 PM
Charlie Moua's Avatar
as long as you have a tuner there to make some minor adjustments you should be able to break it in with that aftermarket cam.
If no tuner is avaible, then yes put in stock cams and start logging in some miles.
pauld
Jun 22, 2007 12:56 PM
hondaluva
10
Dec 8, 2004 06:02 AM
OoCRXoO
May 4, 2003 12:22 PM
B_1_8_hatch
Mar 21, 2003 09:29 PM
