boosted 400hp and im all over the road!
Old 07-23-2007, 03:53 PM
mkw1's Avatar
Default boosted 400hp and im all over the road!
just got my car back from my tuner and when it boosting hard the car goes all over the road pulls right then left and right and left. its all over and very hard to control . had a alinment just before it got boosted drove just fine natural but now that its boosted it all over. i had it check today and every things right on but its lowered so the top of the wheels are tiped in a little but not much .2 off. any help?
Old 07-23-2007, 03:57 PM
nowtype's Avatar
Default Re: boosted 400hp and im all over the road! (mkw1)
It's called torque steer. It comes with driving a high horsepower FWD vehicle. Get the car professionally aligned again to make sure everything is kosher, but most likely its simply torque steer.
Old 07-23-2007, 03:58 PM
zaccers's Avatar
bingo
Old 07-23-2007, 03:59 PM
red02s2k's Avatar
it's called power lol. that and when you got the alinment done with or without the turbo? b/c the turbo kit depending on what the size of the turbo is going to add some weight... i know when i put my b20 and the turbo on it made about a 150 pound difference between the d15 i had stock...
Old 07-23-2007, 04:08 PM
mkw1's Avatar
Default Re: boosted 400hp and im all over the road! (red02s2k)
dont think its torque steer in 3rd it all over not because your shifting or on off the throttle. itso bad it you could never race next to any body its to hard to control. darts back and forth while floored through out any one gear
Kyle R's Avatar
Torque steer in my friends turbo colt was rediculous. Definately the same problem you are having.
Old 07-23-2007, 04:10 PM
ProjectBB6's Avatar
Default Re: boosted 400hp and im all over the road! (herecomesboost)
high hp rwd cars tend to have a similar problem out the gate too... I dont think there is much you can do but hone in your suspension.
Old 07-23-2007, 04:16 PM
1992Si's Avatar
You need a suspension that is up to the task of handling all the power. We had the same problem a few years back.
IM rota92 and tell him to hook you up with Progress. He talked with them and they designed a suspension for the car that made a world of difference.
When I was street tuning the car before the suspension, the Tuner said "he'd been in 400hp B series cars but our single cam with a GT35R was the first car that scared him. After the Progress the car drove straight when it hit boost.
The car runs down the track straight with 568whp 406ftlbs.
Old 07-23-2007, 04:18 PM
RCautoworks's Avatar
B or D series ? Torque steer also has a lot to do with unequal axles.
http://www.aa1car.com/library/wheel_alignment.htm
"This is also what causes "torque steer" (a sudden steering pull) in some FWD cars that have unequal length halfshafts. "
Where did you get it aligned, are they use to aligning high horsepower cars or did you go to like an every day place like jiffy lube. Places that deal with higher hp cars will know how to help you more.
Old 07-23-2007, 04:21 PM
racin jasin R's Avatar
Default Re: boosted 400hp and im all over the road! (RCautoworks)
you will get use to it by the end of the week
Old 07-23-2007, 04:29 PM
mkw1's Avatar
b series gsr
Old 07-23-2007, 04:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkw1 &raquo;</TD></TR><TR><TD CLASS="quote">b series gsr</TD></TR></TABLE>
I would look into going to a shop that specifically deals with aligning higher horsepower cars.
Old 07-23-2007, 04:35 PM
Mr.Death's Avatar
Do you have an open diff?
Old 07-23-2007, 04:37 PM
mkw1's Avatar
Default Re: boosted 400hp and im all over the road! (Mr.Death)
no type r lsd
Old 07-23-2007, 05:01 PM
tegdude227's Avatar
and a chamber kit to fix that tire tucking in
Old 07-23-2007, 05:05 PM
BoOsTiN Dc2's Avatar
Default Re: (tegdude227)
check the bolts that hold the steering rack. I had energy suspension bushing and 2 of my bolts came loose before and everytime i boost i would be all over the lanes next to me...
Old 07-23-2007, 05:34 PM
VtecCarHauler's Avatar
Default Re: (BoOsTiN Dc2)
it is alingment. Trust me I know. If you step on it in 4th gear not spinning and it is still all over the place it is alingment (wheel bearings, tie rod ends...) for sure. When the front suspension is unloaded because of acceleration the alingment becomes a big factor. Get the car's alingment re-checked and post up what happens. Ther is something loose. Also alot of negative camber doesn't help either. Wheel bearings tend to go too as soon as you start making good power.
Old 07-23-2007, 06:17 PM
blackeg's Avatar
dude im in the same boat. 400hp and ~2300 lbs. its a pretty common thing to happen. i ordered a beefy suspension to help combat the problem
Old 07-23-2007, 06:22 PM
b18tegg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death &raquo;</TD></TR><TR><TD CLASS="quote">Do you have an open diff? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkw1 &raquo;</TD></TR><TR><TD CLASS="quote">no type r lsd</TD></TR></TABLE>
Old 07-23-2007, 06:26 PM
boostedgsr1234's Avatar
Default Re: (blackeg)
same here i have a great alignment, great suspension, and almost 400whp,and im all over the place its deff. torque steer. i have a solution however that will work...
hold the expletive on lol
Old 07-23-2007, 06:37 PM
jayman322's Avatar
Default Re: (boostedgsr1234)
traction bars maybe? do you or do you not have power steering still?
Old 07-23-2007, 06:46 PM
mkw1's Avatar
Default Re: (jayman322)
got power streering, but no traction bars
Old 07-23-2007, 08:44 PM
Turbo-Honda's Avatar
I had the same problem when running my coupe at 400hp, but after the type r rear sway bar install and a good realignment, the car start going pretty strait forward. I test out boosting in 3rd at around 25* turn on the free way and the car still handle like a champ.
You should look into good rear sway bar, it a good investment you ever made.
Old 07-23-2007, 08:51 PM
blinx9900's Avatar
Default Re: (mkw1)
in for the info
Old 07-23-2007, 09:02 PM
bigbadboy's Avatar
get some traction bars, a good aligment and some sticky tires and u'll be straight
Quick Reply: boosted 400hp and im all over the road!
