boost+Vtec
Old Oct 15, 2008 | 09:13 PM
rmn's Avatar
rmn
Default boost+Vtec
Hi honda-tech ppl.
I have B16 + xs engineerin turbo kit (stage2), and I have a problem after vtec engage, there is no torque and starts popping - mxture were too rich.
After lean (now 10.5-11 afr) I checked fuel tables and found that air cosuption is too low. The car run strong only on small lobes.
The cam are spoon, tried degreeing them but it doesnt work.
I can get JDM ITR spec 96 cams - will they solve my problem?
stock b16+ cometic 0.72 HG
ems: hondata s300
run 9 psi.
thank you in advance and sorry for my english - this is not my native language, i am from Russia.
Old Oct 15, 2008 | 09:17 PM
tony413's Avatar
Default Re: boost+Vtec (rmn)
your AFRs are still high but then again is the car currently in russia and whats the temp and elavation ?
also switching to a bigger cam wont make your problems go away
Old Oct 15, 2008 | 09:39 PM
rmn's Avatar
rmn
ITR cams a little smaller then the spoon sport cams, so figured if i can reduce overlap it can help.
Ambient T +5 C , IAT is 35-40c,EGT 800 C (full throtle) elevation approx 500 meters above sea level
Old Oct 16, 2008 | 06:53 AM
tony413's Avatar
Default Re: (rmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmn &raquo;</TD></TR><TR><TD CLASS="quote">ITR cams a little smaller then the spoon sport cams, so figured if i can reduce overlap it can help.
Ambient T +5 C , IAT is 35-40c,EGT 800 C (full throtle) elevation approx 500 meters above sea level</TD></TR></TABLE>
for the americans
Ambient temp= 41*F
IAT= 95*F to 104*F
EGT= 1472* F
Elavation= 1640 feet
work on your AFR's and how are you degreeing your cams? with a cam fixture kit or by cam gears ? you may want to do both and retune the car.
Old Oct 16, 2008 | 08:03 AM
rmn's Avatar
rmn
I have adjustable cam gear - so I tried to gegreeing them both advance and retard - expecting that air cosumption will rise on the vtec lobes. For example i have 55% of duty cycle on low cams@6000 rpm, and only 65% on vtec @8000 rpm. injectors are RC750cc.
AFR is rich but the mixture permanent 10.5-11
Old Oct 16, 2008 | 11:14 AM
LastGenEK's Avatar
Default Re: (rmn)
DO you have a exhaust and cat converter?
If you have your catalitic converter on then i sounds like its cloged!
Old Oct 16, 2008 | 03:22 PM
tony413's Avatar
Default Re: (rmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmn &raquo;</TD></TR><TR><TD CLASS="quote">I have adjustable cam gear - so I tried to gegreeing them both advance and retard - expecting that air cosumption will rise on the vtec lobes. For example i have 55% of duty cycle on low cams@6000 rpm, and only 65% on vtec @8000 rpm. injectors are RC750cc.
AFR is rich but the mixture permanent 10.5-11</TD></TR></TABLE>
i know it gets cold in russia but i think that car needs a retune. rework your AFRs. and can you shed some light on what your set-up is
Old Oct 16, 2008 | 07:10 PM
rmn's Avatar
rmn
Thanks for everyone reply.
My Civic has a straihgt catback since the car were NA, it might be restrictive, but not critical 60mm (2.5).
I do not use the car now, it is rainy and cold.
I keep this afr because the car not tuned well yet, and will continue as second rain stops.
Old Oct 16, 2008 | 07:17 PM
tony413's Avatar
Default Re: (rmn)
I keep this afr because the car not tuned well yet, </TD></TR></TABLE>
that could be the issue
Old Jun 2, 2009 | 07:43 PM
rmn's Avatar
rmn
my problem solved, on itr cams car run like it shoul be.
I have torque after vtec kicks in, air consumption rise (goal afr is 11.5, boost - 9 psi).
Spoon cams did not work at all in vtec lobes, at least on my setup.
stock b16, cast log mani, avo-turbo with t25 footprint(based on gt2871 internal gate) 2.5 exhaust - as you can see t25+log mani+internal gate and 2.5" pipe - make exhaust restrictive.
any inputs are wellcome
Rotten Egg
Jun 2, 2009 07:44 PM
jansenrw
Mar 9, 2005 03:57 PM
Redsun
Aug 12, 2004 10:51 PM
B2FiNiTY
Jun 4, 2002 06:51 AM
JDM R98
Aug 2, 2001 12:26 AM
