Boost surge....best way to reduce it...?
Old Jun 12, 2005 | 12:28 AM
turbo95eg6's Avatar
Default Boost surge....best way to reduce it...?
What are the main causes for boost surge...? Im experiencing some at full boost (boost fluctuates between 13-14psi) I can hear the turbo spool fluxuate up and down.
Im using a blits SBC II boost controler, tial 38mm wastegate with a 6psi spring. Some input would be great
Old Jun 12, 2005 | 02:42 AM
project dc2's Avatar
Default Re: Boost surge....best way to reduce it...? (turbo95eg6)
you're only supposed to double the wastegate spring setting.
6 psi spring- max = 12 psi.
Old Jun 12, 2005 | 03:10 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Boost surge....best way to reduce it...? (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">you're only supposed to double the wastegate spring setting.
6 psi spring- max = 12 psi. </TD></TR></TABLE>
Old Jun 12, 2005 | 10:44 AM
turbo95eg6's Avatar
Default Re: Boost surge....best way to reduce it...? (wantboost)
should this be the only reason for the cause...?
Old Jun 12, 2005 | 11:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo95eg6 &raquo;</TD></TR><TR><TD CLASS="quote">should this be the only reason for the cause...?</TD></TR></TABLE>
i would think its a good reason.
Old Jun 12, 2005 | 12:05 PM
turbo95eg6's Avatar
I heard you can triple the max of the spring....is that wrong...? is boost surge very bad for your turbo? What size spring would you reccomend...?
Im running 9psi on the street, 14 track.
Could it also be my blow off valve...? Its bout 8 years old
Modified by turbo95eg6 at 1:17 PM 6/12/2005
Old Jun 12, 2005 | 01:32 PM
TheShodan's Avatar
Moderator
You cannot triple the max spring setting. You can use a 8.5psi spring and go from there.
Old Jun 12, 2005 | 03:21 PM
turbo95eg6's Avatar
Default Re: (TheShodan)
K, will do
Old Jun 12, 2005 | 07:46 PM
turbo95eg6's Avatar
Default Re: (turbo95eg6)
it usualy does it after 5 runs or so....why is that..? If its caused by heat, why?
PINKS
Jan 22, 2007 01:12 PM
95srv
May 12, 2006 07:09 AM
5l-eater
Oct 20, 2004 03:26 PM
hatchattak
Mar 9, 2004 02:15 PM
Cyber ITR
Jan 19, 2004 03:38 AM
