Boost stays until redline on small T25
Old Dec 23, 2005 | 10:26 PM
SWC's Avatar
SWC
Default Boost stays until redline on small T25
I'm running 10psi on DSM T25. The boost hold 10psi all the way to redline. It doesn't even taper down 1psi. Is it okay to push long run on highway in high gears? For the safety, it should taper down little bit, right? I'm running stock D16 block with crome tuned ecu.
Thanks.
Old Dec 24, 2005 | 02:37 AM
VNTEC's Avatar
B A N N E D
Default Re: Boost stays until redline on small T25 (SWC)
If you occur any type of boost drop its because your turbine isnt pushing enough air for your motor. I wouldnt push that t25 for long periods of time they are really small turbines and would likely fail if pushed on too much.
Old Dec 24, 2005 | 07:30 AM
s2kdre's Avatar
Default Re: Boost stays until redline on small T25 (VNTEC)
not bad but t25's dont hanlde more than 8k rpms.
Old Dec 24, 2005 | 07:33 AM
integranator's Avatar
My t25 starts to lose power right around 5500. From 250 to aroudn 220 by 7200. So thats around 14psi to about 10. All power though from about 3500 up.
Old Dec 24, 2005 | 10:33 AM
SWC's Avatar
SWC
Default Re: Boost stays until redline on small T25 (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">not bad but t25's dont hanlde more than 8k rpms.</TD></TR></TABLE>
My redline is only 7200rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator &raquo;</TD></TR><TR><TD CLASS="quote">My t25 starts to lose power right around 5500. From 250 to aroudn 220 by 7200. So thats around 14psi to about 10. All power though from about 3500 up.</TD></TR></TABLE>
Are you pushing 14psi on T25? Is it efficient with that much boost? On your dyno graph, where is the sweet spot both HP and TQ band?
Old Dec 24, 2005 | 10:56 PM
sweet spot ? I guess anywhere around 3grand and up?
Old Dec 25, 2005 | 07:09 AM
SWC's Avatar
SWC
Default Re: Boost stays until redline on small T25 (integranator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator &raquo;</TD></TR><TR><TD CLASS="quote">sweet spot ? I guess anywhere around 3grand and up?</TD></TR></TABLE>
The rpm range from the highest TQ to the highest HP
93GS-TypeR
May 15, 2008 06:52 AM
RTW DC2R
Nov 17, 2006 03:19 PM
ras
May 3, 2005 09:14 AM
-iLLuZioN-B18C1
Feb 20, 2004 07:24 AM
DanM
Apr 12, 2003 04:40 PM
