boost spike issues
Old Oct 22, 2008 | 09:16 AM
dhn's Avatar
dhn
Default boost spike issues
i got street tuned and car ran fine. Im tuned on 11lbs for now. When i do WOT pulls my boost spikes to around 13-15 and i hit boost cut and it like hits a brick wall. What could cause this? im using a deltagate wastegate and an MBC. I have an EBC which im going to hook up later tho. My friend had a deltagate and had no issues but i read that it does have some issues. i unhooked my mbc and ran off of wastegate but only got like 3 lbs out of it..and i have a 7lb spring. anything else i should look for?
Old Oct 22, 2008 | 01:04 PM
yakuza's Avatar
Pics & list up of complete setup please? turbo, manifold, down piple, exhaust, ECU, map sensor, etc !!!!
Old Oct 22, 2008 | 06:31 PM
blwn95civic's Avatar
Default Re: boost spike issues (dhn)
check all vaccume lines on the wastegate, possibly one is off or has a hole in it. If it didnt spike on the dyno then its not your mani, so im guessing your problem is within your wastegate if your only seeing 3lbs on a 7lb spring. But like posted above... more info
Old Oct 27, 2008 | 10:52 AM
DxTrix's Avatar
Default Re: boost spike issues (blwn95civic)
Where is my FUC*%$# dizzy?
Old Oct 27, 2008 | 04:52 PM
platinum00's Avatar
Default Re: boost spike issues (DxTrix)
If it held at 11 before and now spikes to 13-15, get a vac leak tester. If its always spiked, thats fairly common depending on your wastegate and placement.
-platinum
Old Oct 27, 2008 | 06:01 PM
Turbo-charged's Avatar
Default Re: boost spike issues (platinum00)
load is different from the dyno to the road/track....and most likely your problem. thats why we spend good money for good boost controllers.
Old Oct 27, 2008 | 06:06 PM
miller's Avatar
Default Re: boost spike issues (Turbo-charged)
boost controller, smooch controller. Check valves FTW
Boosted00
Jan 19, 2018 01:51 PM
R.A.T.
Apr 8, 2009 05:43 PM
iTz On!!!
Mar 18, 2008 06:10 PM
vtec.dc2
Aug 27, 2004 05:57 PM
Wo-Nelly
Feb 23, 2004 01:28 PM
