boost readings at idle?
Old Oct 16, 2002 | 03:19 AM
CalvitoSol's Avatar
Default boost readings at idle?
sup ya'll. i'm not boosted yet but decided to install my older model, blitz mechanical boost gauge for now to save some time for later. well, everything seems ok but during idle, my gauge reads -60hg. i was looking around and everyone mentions 18-20. is my guage broken or are the readings different depending on the gauge because mine reads in bar? btw, i did a search and i couldn't find anything that answered my question. thanx
[Modified by theory48, 12:20 PM 10/16/2002]
Old Oct 16, 2002 | 09:13 AM
1.8T_EG's Avatar
Default Re: boost readings at idle? (theory48)
... i just installed my autometer boost gauge yesterday and it only read 15 hg vac... is this normal?... i did a search and everyone else seems to be in the 18-22 range... lemme know... thanks...
Old Oct 16, 2002 | 09:27 AM
speedymon's Avatar
Default Re: boost readings at idle? (1.8T_EG)
I get -0.74 bar. 14-15psi. Seems kinda high to me.
Old Oct 16, 2002 | 11:16 PM
CalvitoSol's Avatar
Default Re: boost readings at idle? (speedymon)
anyone? is hg different from bar when in vacuum? my gauge reads -60 is that normal? autometers read in psi right?
Old Oct 16, 2002 | 11:38 PM
boostinb18's Avatar
the autometer reads in mm HG vacuum....... adn mine is between 18-26 depends on how hot it is out side....... but what is normal???
Old Oct 16, 2002 | 11:57 PM
Sonny's Avatar
Default Re: boost readings at idle? (boostinb18)
The readings will vary based on gauge, altitude, temperature, etc.
My Autometer gauge was always a bit off...read anywhere from 16" to 19" at idle with my old B16A2.
Sonny
Old Oct 17, 2002 | 12:03 AM
GSRrR's Avatar
Default Re: boost readings at idle? (Sonny)
20 on my autometer. It's broken and will not go pass 20.
Old Oct 17, 2002 | 12:09 AM
boostaholic's Avatar
Actually, Autometer vac/boost gauges read inches of Hg in vacuum. Like Sonny said there are a few factors to take in on your vacuum readings at idle. On a general basis that i've seen, the B series motors run between 17-22 inches of Hg on a good motor at idle.
Old Oct 17, 2002 | 03:43 AM
CalvitoSol's Avatar
Default Re: boost readings at idle? (boostaholic)
i have a blitz that reads in bar. how much is it supposed to read on those?
Old Oct 17, 2002 | 05:49 AM
1.8T_EG's Avatar
... mine only reads 15 inches of Hg... is that a good thing?... or is it a sign of a possible problem... lemme know... thanks...
Old Oct 17, 2002 | 05:52 AM
MikeMAN's Avatar
it is a pretty small difference, so i wouldn't worry TOO much, but there might be a leak somewhere, and where did u t-off ur boost gauge? if you T-off everything at the same spot u won't get an accurate reading either.
hope ya figure this out!,
mike
Old Oct 17, 2002 | 07:07 AM
echo999's Avatar
New User
21-22 @750 rpm on my GSR 98 off of a SBC-iD boost controller.
Old Oct 17, 2002 | 07:37 AM
CalvitoSol's Avatar
Default Re: boost readings at idle? (echo999)
i took a look at my gauge and vacuum reads at cm/hg unlike the autometer that are in/hg. does anyone know how to convert that? thanx
Old Oct 17, 2002 | 07:40 AM
Zeppelin's Avatar
If you are in Colorado Springs this would be correct. You will never get 18-20 numbers at that altitude.
Old Oct 17, 2002 | 07:48 AM
1.8T_EG's Avatar
Default Re: boost readings at idle? (Zeppelin)
thanks for the reply...!!!
Old Oct 17, 2002 | 08:49 AM
fire7882's Avatar
I think you would divide your number by 2.54 giving you 23.6
tr0n9h
Dec 5, 2009 07:43 PM
teamlegacy
Jul 27, 2006 05:40 AM
Eskay@JDMCircle.com
Oct 6, 2004 09:43 PM
JDM_EH2
Sep 18, 2003 09:10 AM
BLKMamba
Jul 27, 2001 10:47 PM
