boost question?
Old Nov 19, 2003 | 08:59 AM
Mi4si's Avatar
Default boost question?
this piece that is supposed to connect to my downpipe from the turbo is bent, well the screws are. what is the best way to unbend them?
Old Nov 19, 2003 | 09:00 AM
baddassduramax's Avatar
Default Re: boost question? (Tncivicracer)
they look like studs, remove them and put new ones in
Old Nov 19, 2003 | 09:59 AM
integranator's Avatar
Default Re: boost question? (civicb18)
some of those look like they can't be merely taken out. You should un bend them- and try not to mess up the threads inside-- then take them out and replace. If the threads are all mess up, you might need to re-tap them-- or you could just force em in!!!!
Old Nov 19, 2003 | 10:29 AM
Quad-Damag's Avatar
Default Re: boost question? (integranator)
Just get new bolts, or weld that sucker on
Old Nov 19, 2003 | 10:49 AM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb18 &raquo;</TD></TR><TR><TD CLASS="quote">they look like studs, remove them and put new ones in</TD></TR></TABLE>
Old Nov 19, 2003 | 11:04 AM
FuzzyGreen's Avatar
Heat em up until they are glowing red with a propane torch then bend them using thick gloves and vise grips.
Importcustomx
Jan 14, 2008 11:44 AM
imadigitalgod
14
May 19, 2007 07:57 AM
damn_import_culture
19
Apr 28, 2007 08:34 AM
guy.
Sep 24, 2006 08:19 AM
h22a193
Jun 20, 2004 05:02 PM
