Boost Problem? Help!
Old Feb 10, 2004 | 04:01 AM
btrim23's Avatar
Default Boost Problem? Help!
Alright, just got my boost gauge hook up and its reading 4-5 lbs of psi and the a/r fuel ratio is rich. Is this correct or its something wrong? I am unsure about the wastegate spring, I heard it could be a 5 lbs spring or 7? and it comes with the drag kit.
Old Feb 10, 2004 | 07:45 AM
platinum00's Avatar
Default Re: Boost Problem? Help! (btrim23)
if have have a 5 psi spring and it's reading 5 psi.
how could that not be correct.
as for the a/f rich is better then lean, but if you not measuring that with a wideband. you never really know what you have..
platinum.
Old Feb 10, 2004 | 07:48 AM
Johnyquest's Avatar
Default Re: Boost Problem? Help! (platinum00)
If your wastegate is getting a boost signal from before the intercooler, i.e. the turbo, it will boost less due to the i/c's pressure loss. If you tap a pressure signal from your intake manifold, it will read the actual pressure your engine is seeing, and therefore produce another pound or two, depending on how bad your i/c's pressure loss is.
Matt
Old Feb 10, 2004 | 09:02 AM
btrim23's Avatar
Default Re: Boost Problem? Help! (Johnyquest)
thanks. unfortunitely, boost was hook up by a friend so i thought the reading was wrong.
KevinEF7
Oct 7, 2013 10:43 PM
DarryCar
Apr 18, 2012 03:27 PM
vg7z
Sep 20, 2006 08:27 PM
Nextelbuddy
Aug 25, 2003 01:56 PM
dwilson
Nov 30, 2002 11:31 PM
