boost hickup
Old May 13, 2006 | 01:36 PM
LSVtechnologytur...'s Avatar
Default boost hickup
Hey does anyone have an idea why my car would drop from12.8 psi to 9, then go back up within a 1000rpm range (from around 5k - 6krpm) This is right around vtec engagement. My plugs are all gaped to .028 (ngkbkr7e)
When i rev the car out through that rpm range it back fires, sometimes really bad, but not always.
a little background:
ls/vtec
stock ignition
tuned on crome
thanks for any help
Old May 13, 2006 | 01:40 PM
nonvtecD's Avatar
psi drop sounds like a boost controller or wastegate. Backfire sounds like fuel or ignition (tune). Eliminate what you know is good. When did it start, did it do it while you were being tuned?
Old May 14, 2006 | 07:14 AM
Default Re: (nonvtecD)
it happened while we were tuning. It was really bad at first, but once we changed the plug gap it got alot better. I think its backfiring because of the sudden change in pressure. Does it sound like it could be a ignition problem? The reason i dont think its boost controller/ wastegate is because the pressure goes back up after 6000rpm
Old May 14, 2006 | 08:15 AM
nonvtecD's Avatar
Yeah, sounds like ignition ot me. I've never had ignition problems so I'm not sure what you should replace first... Coil, I know ignitors on Hondas tend to go bad.
Old May 14, 2006 | 11:52 AM
thanks, i'll start replacing stuff and see what happens
Old May 14, 2006 | 09:08 PM
type Gendy's Avatar
Default Re: (LSVtechnologyturboboost)
Same thing was happening on my car until my ignitor finally quit and i replaced it
vtec FTW
Old May 14, 2006 | 09:34 PM
qfast817's Avatar
Default Re: (type Gendy)
yea ingition problems
Kid-jdm-teggy
Engine Management and Tuning
Aug 14, 2015 08:18 AM
LST2
Nov 24, 2007 11:16 AM
Chris F
May 15, 2005 07:57 AM
ATS*Mark
Feb 2, 2004 04:22 PM
turboex
Feb 12, 2002 12:21 PM
