Boost Hesitation
Old Oct 6, 2004 | 08:37 AM
Endoe's Avatar
Default Boost Hesitation
i got a 00 stock LS with GT30R Ball Bearing Turbo...3inch DP..turbosmart wastgate..stock exhaust with 2.25 piping..450dsm injectors..ive just got a base map for my 450 dsm injectors using unberdata...but now my car hesitate right when its about to boost at 3500rpm.... before it never did that until i threw in the 450 and the new chip using uberdata...help me out guys..let me know if you need more info...???
Old Oct 6, 2004 | 08:38 AM
Boosted2K's Avatar
Default Re: Boost Hesitation (Endoe)
you should not be boosting on a basemap anyway. Get that thing tuned, probably a fuel issue. Your tuner should be able to fix it
Old Oct 6, 2004 | 09:01 AM
mattEG's Avatar
Uhh.. if you just made a basemap based on the instructions at the Uberdata forums you're going to be detonating hard in boost already.. This is because your ignition timing is WAY too advanced when you make that basemap..
Basemap = drive to tuners not cruise on.
Old Oct 7, 2004 | 12:30 AM
Endoe's Avatar
Default Re: (mattEG)
we didnt advance it... but i never had any problem with my stock injectors and FMU but after i installed it, it starts doing that...it starts to boost at 3 throughout the whole rpm without any hesitation....it would just straight boost after 3500 rpm...
Old Oct 7, 2004 | 04:16 AM
1bad-eg's Avatar
Default Re: (Endoe)
You just said though that the car started to hesitate after the uberdata basemap. Get the car tuned before you do any damage to your ride.
Old Oct 7, 2004 | 07:11 AM
Endoe's Avatar
Default Re: (1bad-eg)
damm that sucks...well i guess if thats the only way...ive heard some rumors that DSM injectors are not good with hondata is that true? Anyone? Well what do i use than?
PhrequenC
Engine Management and Tuning
Feb 22, 2009 10:05 PM
project civic
Sep 5, 2005 04:07 PM
hndarcrb18c1
Apr 8, 2004 01:25 AM
HotRodTeg
Sep 9, 2003 10:52 AM
cjmech
Dec 11, 2002 03:41 PM
