Boost gauge problem ..
Old Feb 14, 2004 | 08:03 PM
DEVIN22CBR's Avatar
Default Boost gauge problem ..
So ..My gauge only shows -15 to -16 hg at idle ..Noramly people are running -20 hg. My car boost fine..runs fine ...Think I have a small leak possibly ? Anyone else have this problem ?
Old Feb 14, 2004 | 08:17 PM
Hoosier Daddy's Avatar
Default Re: Boost gauge problem .. (Im Rick James)
Does it read what it should when in boost?
Old Feb 14, 2004 | 08:20 PM
DEVIN22CBR's Avatar
Default Re: Boost gauge problem .. (Hoosier Daddy)
Well ...That could also be a prob ...It reads 5 psi and kinda spikes to 8 but thats called for on a GReddy kit .
Old Feb 14, 2004 | 08:29 PM
Rod.'s Avatar
mine idles at 15-16 hg at idle. When im on the road and let off the gas, it goes to 20 hg. I thought that was kind of weird but not sure.
Old Feb 14, 2004 | 08:30 PM
DEVIN22CBR's Avatar
Default Re: Boost gauge problem .. (redturbocivic)
Same with mine ..
Old Feb 14, 2004 | 08:34 PM
Boostin Ex's Avatar
A leak would cause you to have a false vac reading but my d16y8 pulled a solid 20-22 hg and it still pulled that with a cracked ring land in the end too. It just blew out a nice cloud when i hit boost
Old Feb 14, 2004 | 08:39 PM
DEVIN22CBR's Avatar
Default Re: Boost gauge problem .. (Boostin Ex)
Damn ...How many lbs were you pushing ? I def should be seeing -20 hg I dunno whats up
Old Feb 14, 2004 | 08:54 PM
Boostin Ex's Avatar
I was running 7psi with a greddy kit but i would spike anywhere from 9-10 psi trying to hold 7 psi to red line with my profec A. For fuel I just had a inline pump and a fmu. It took me about 30,000 miles to kill the sohc and about 5-6 150+ mph top speed runs.
Old Feb 14, 2004 | 09:02 PM
DEVIN22CBR's Avatar
Not bad .
Old Feb 14, 2004 | 09:32 PM
Dengar's Avatar
I had the same problem with my boost gauge when i was running the greddy kit. I found out the problem was in the gauge itself. Where the hose was connecting to the back of the gauge i used some of that plumbers take to seal the connection. I after i did it fixed everything and i consistently read -20 on the gauge.
Old Feb 14, 2004 | 09:37 PM
DEVIN22CBR's Avatar
Default Re: Boost gauge problem .. (Dengar)
You mean teflon tape ?thanks
Old Feb 14, 2004 | 09:56 PM
Boostin Ex's Avatar
Remember that if you over tightin your fitings that your line is in it will kink the line and also cause it to leak.
DEVIN22CBR's Avatar
Yeah I think Ive gt a kunk or something going wrong
Old Feb 15, 2004 | 12:08 AM
integrx's Avatar
New User
well i'll let you know that your not alone + i'm running the greddy turbo 15g... Mine read 16 vac on idle, sometimes it would go down to 20. And the boost would only read 5psi when i floor it and 9psi in 4th gear. Also it can read about 9psi when its 3/4 throttle. not too sure if its a vac leak yet, really had no time to figure it out.
Old Feb 15, 2004 | 05:15 PM
Dengar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Im Rick James &raquo;</TD></TR><TR><TD CLASS="quote">You mean teflon tape ?thanks</TD></TR></TABLE>
Yes exactly..I had crushed at least two of those little ***** inbetween the boost gauge connection before I finally taped that damn thing up and fixed the problem.
Old Feb 15, 2004 | 05:22 PM
DEVIN22CBR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dengar &raquo;</TD></TR><TR><TD CLASS="quote">
Yes exactly..I had crushed at least two of those little ***** inbetween the boost gauge connection before I finally taped that damn thing up and fixed the problem.</TD></TR></TABLE>
**** mine are crushing also. So I need telpon tape to make that stop ?
Old Feb 15, 2004 | 05:24 PM
smurfey002's Avatar
i am running no boost right now and only have 45K on my car and my vafcII reads about 11-12psi in vacume and about -13-14psi when i let off the gas while going. my car runs awesome and responds great, i dont think i have a vacume leak or anything.....any opinions?
Modified by smurfey002 at 3:00 AM 2/16/2004
Old Feb 15, 2004 | 05:32 PM
DEVIN22CBR's Avatar
Default Re: (smurfey002)
Sounds like a vacuum leak lol. Epsecially is yoru not making any boost at all. Was the turbo kit used ? Everything put on right
Old Feb 15, 2004 | 05:59 PM
smurfey002's Avatar
Default Re: (Im Rick James)
thats the thing. the kit isnt on yet. i still have been told 20ish is normal for everyday healthy cars that dont have boost.
Old Feb 15, 2004 | 06:08 PM
DEVIN22CBR's Avatar
Yeah -20hg should be showing boost or n/a ....You might have a leaky gauge like we do. Tephlon tape it up and go from there. Could have a small crack in one of your hoses .
Old Feb 15, 2004 | 07:10 PM
CaptainMorgan's Avatar
I think you are fine. I believe 15-21 is normal. For each 1000 feet you go up in elvation your vaccum increase by 1 hg. best way to test vaccum leak is take a propane tank with a hose hooked to it. Go around the engine where you think the leak is, with the propane and if there is a leak then the enigne rpm will change.
Old Feb 15, 2004 | 07:11 PM
DEVIN22CBR's Avatar
Or this .. http://www.slcstreetracing.com...t.asp
Old Feb 16, 2004 | 05:27 PM
smurfey002's Avatar
yea, but i dont have a gauge hooked up just yet (well anymoer that is) it was my vafc that was giving me the -10-12 readings. btw, i am reading in psi. you guys are too right?
Old Feb 16, 2004 | 06:32 PM
DEVIN22CBR's Avatar
We're reading in Hg
Old Feb 16, 2004 | 06:36 PM
diputs's Avatar
-10-12 psi of vacuum...no way. I bet it's inches of Hg.
