Boost Gauge Install: Ferrules confuse me
Old Oct 9, 2005 | 03:24 PM
DraconicPenguin's Avatar
Default Boost Gauge Install: Ferrules confuse me
Ive been trying to figure out these directions for my Autometer boost gauge, and the ferrule thing is confusing me.
On the directions, it looks like the ferrule is those two cone things (B) put together, but if i do that, the sealing nut (C) does not reach the adapter (A). do i just use one of the cones, and crank it down real tight so it compresses the tube? or am i missing something...
thanks
Old Oct 9, 2005 | 03:40 PM
IHaveTurbos's Avatar
Ok use A on the gauge, and on the plastic tube put c followed by b and then tighten down to a.
Old Oct 9, 2005 | 03:41 PM
zbaber's Avatar
Default Re: Boost Gauge Install: Ferrules confuse me (Draconic Penguin)
u just use one of the little cone things... there are a couple diff. designs of the ferrules... one looks like the picture.. one looks like what u have shown in your photo...
Old Oct 9, 2005 | 03:42 PM
Johnyquest's Avatar
You're missing peices. The ferrule that is pictured in the directions is what it should look like. You should have found it inside the connector thingy when you took it apart. If not, then you are missing it. It slides right over the plastic tube as pictured.
Hope you find it-- g'luck
Matt
Old Oct 9, 2005 | 03:51 PM
zbaber's Avatar
Default Re: Boost Gauge Install: Ferrules confuse me (Johnyquest)
u will use "a" mounted to the back of the gauge, then slip "c" over the tube, and then put 1 of the cone things "b" over the tube in so it will sandwich in between "a" and "c"... put the smaller end of the cone towards "a"... and then tighten up "c" ... u should be good to go...
Old Oct 9, 2005 | 03:54 PM
zbaber's Avatar
Default Re: Boost Gauge Install: Ferrules confuse me (zbaber)
i just hooked up my autometer gauge last night, they give u those extra parts in case u have a vacume manifold, or are tapping a new hole in your intake manifold,
Old Oct 9, 2005 | 03:59 PM
thanks, got exactly the information i needed.
ill put it together tonight and hopefully it'll work
Old Oct 9, 2005 | 04:26 PM
peiku's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zbaber &raquo;</TD></TR><TR><TD CLASS="quote">u will use "a" mounted to the back of the gauge, then slip "c" over the tube, and then put 1 of the cone things "b" over the tube in so it will sandwich in between "a" and "c"... put the smaller end of the cone towards "a"... and then tighten up "c" ... u should be good to go...
how come when i did this, the tube still manages to slide out?
Old Oct 9, 2005 | 04:28 PM
Default Re: Boost Gauge Install: Ferrules confuse me (peiku)
i believe you have to tighten it down enough that it crushes the little cone. im about to try it, ill let you know how it goes
Old Oct 9, 2005 | 04:41 PM
yes, it worked!
i put one wrench on A and turned C with another wrench until it was nice and tight
the vacuum line is firmly stuck in there
Old Oct 9, 2005 | 05:01 PM
zbaber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku &raquo;</TD></TR><TR><TD CLASS="quote">how come when i did this, the tube still manages to slide out?</TD></TR></TABLE>
u will have to tighten it a bit... putting the smaller end of the cone towards "a" will cause the smaller end to crush in on the tube, which will lock the tube in place... if u get it properly tightened u shouldnt be able to pull the tube out...
Old Oct 14, 2005 | 08:58 PM
mike93eh
Guest
Posts: n/a
screw all that ****. i threw all that crap away and just hooked a rubber vacuum host on there.
Old Nov 17, 2005 | 09:28 PM
R6E6I6D's Avatar
Default Re: (mike93eh)
wont a rubber hose balloon under boost and crimp under vac?? I think i fucked mine up it doesnt read boost only vac sooo I think inm gunna get a 1/8 inch pipefitting and hook a small piece of vac rubber hose to nylon tube and to pipe fitting and ZIP tie tell ya how it goes!!
a1320honda
May 27, 2008 03:53 AM
blinger
May 18, 2007 02:00 PM
zseeanz
Sep 27, 2004 04:10 AM
powerls
Dec 21, 2003 06:47 PM
TurboJesse
Mar 18, 2003 11:33 AM
