boost gauge install
Old May 28, 2003 | 09:06 PM
MachAF's Avatar
Default boost gauge install
Did anyone else find running the wires for a boost gauge a pain in the ***?
I plan on using an A pillar and running the wires long that tiny area was a pain. I had to use a coat hanger to jam them through there. Then when I was wiring the electrical connection to the dimmer switch i broke the dimmer switch trying to pull it out . Fix that now. Dimmer switch was only place I remembered to wire the gauge for it light. Still trying to find a place for the ground wire as its very short.
If anyone knows how to make this eaiser for me. I can see how much of a pain the egt and oil pressure gauges will be.
Old May 28, 2003 | 11:34 PM
B18EG6's Avatar
Default Re: boost gauge install (MachAF)
Check yer IM... sent ya some help. What kind of gauges are they? IF you get reallllly confused ill send you step by step with pictures
Old May 29, 2003 | 02:04 AM
sak's Avatar
sak
http://www.team-integra.net/se...gauge
You can thank me later.
Old May 29, 2003 | 04:49 AM
T-RO's Avatar
It was a pain for me to run my wires for my A-pillar too. I recommend threading a length of thinker wire down (easier to work with the thicker wire), then tape your thin wires that you will use to it and pull it back through.
For ground I am using a bolt in the chassis right next to my fuse box.
B16Drag
Sep 16, 2009 09:12 PM
jisu009
Jul 1, 2004 03:34 PM
Caoboy
Jan 22, 2004 06:48 PM
djnikko
Nov 28, 2003 12:35 AM
