boost gage install help!
Old Apr 17, 2003 | 12:08 PM
shming123's Avatar
Default boost gage install help!
is it hard to install a boost gage?? could i do it? or should i not take the chance of messing something up? (gsr turbo) pics would help if ya have any...THANKS!
Old Apr 17, 2003 | 01:06 PM
shming123's Avatar
Old Apr 17, 2003 | 01:12 PM
T3's Avatar
T3
Default Re: boost gage install help! (shming123)
http://www.seansa4page.com/mya....html
http://www.carreview.com/proje....aspx
http://www.roadraceengineering...s.htm
Old Apr 17, 2003 | 01:21 PM
shming123's Avatar
any pics or diagrams for a honda? i am new at this.
Old Apr 17, 2003 | 01:48 PM
Diego Boost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shming123 &raquo;</TD></TR><TR><TD CLASS="quote">is it hard to install a boost gage?? could i do it? or should i not take the chance of messing something up? (gsr turbo) pics would help if ya have any...THANKS!</TD></TR></TABLE>
You can do it! It's a pita running the vac line through the firewall and if your gonna use a pillar guage pod it's gonna be a bitch running the power plug and vac line, other than that it's easy. All you really need to know is where to get your power source from, where to ground, and where to 'T' in the vac line from the boost guage.
Old Apr 17, 2003 | 02:17 PM
shming123's Avatar
i have a the Drag turbo kit, w/fuel regulater, and stuff, so i already have like 2 or 3 "T"'s...where should i put it? is that all there is to it? i just need this temporarily, and i don't care if it lights on or not, so do i need to connect the wires for it to fully work? or just for the light to come on? thanks.
Old Apr 17, 2003 | 02:28 PM
Pengo's Avatar
Default Re: (shming123)
if its mechanical u only need to hook up the vac line and make sure u can see the thing when ur driving. or have someone else watch it at least. the install is simple, u just need to plan out where ur gonna run ur lines and where u want it to be mounted
Old Apr 17, 2003 | 03:20 PM
shming123's Avatar
i know, but that is the only question i have---how and where do i mount the vaccuum line from the gage?
Old Apr 17, 2003 | 04:16 PM
shming123's Avatar
^^ ?? the hose from the wastegate to the turbo? the hose from the blow off valve to the fuel regulator stuff??? ?????????
Old Apr 17, 2003 | 05:28 PM
shming123's Avatar
any1?
Pengo's Avatar
t off of one of ur vacuum lines. just pick one off of the manifold. fpr, brake booster, etc. so u have two main options. tube from gauge goes into the T. as for the other two ends of the t, u can either cut the stock vacuum line and stick one end of each on the T, or take off one end of the vacuum line, put that one one end of the T, and run another small vacuum line from the other end of the t to wherever it used to go.
Old Apr 17, 2003 | 05:38 PM
Poop111444's Avatar
Default Re: (Pengo)
Dood this may seem a bit weird....but if you buy the Autometer gauge it comes with instructions. If you follow them you should be ok
Old Apr 17, 2003 | 05:55 PM
MiraiZ's Avatar
Default Re: (si_mekanik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_mekanik &raquo;</TD></TR><TR><TD CLASS="quote">Dood this may seem a bit weird....but if you buy the Autometer gauge it comes with instructions. If you follow them you should be ok </TD></TR></TABLE>
LOL
Old Apr 17, 2003 | 06:02 PM
acman1's Avatar
the instructions rnt the greatest in the world...
Old Apr 17, 2003 | 06:22 PM
MiraiZ's Avatar
Default Re: (acman1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acman1 &raquo;</TD></TR><TR><TD CLASS="quote">the instructions rnt the greatest in the world...</TD></TR></TABLE>
that's probably because its not the hardest thing in the world to do
Old Apr 17, 2003 | 10:42 PM
Pengo's Avatar
Default Re: (MiraiZ)
hehe yea the instruction pretty much cover all u need to know. i guess it could still be hard if u dont know what ur lookin for. i know some people dont even know where vac lines are etc, but u gotta learn sometime anyway. but i think my friends hatchie had the stock stickers under the hood still and even had a chart that showed all the vac lines. but if not, do ur research in the archives or break out the helms .
si-unit
Jan 26, 2005 11:46 AM
ProjectLudeSiR
Aug 23, 2003 03:59 AM
speeds
Mar 17, 2003 03:51 PM
poison
Apr 14, 2002 10:44 AM
