Boost Fluctutates
Old Jan 25, 2010 | 04:14 AM
b20beast83's Avatar
Default Boost Fluctutates
Hello,
My boost Fluctutates, i do not get consistant 14PSI From Full boost [4500-8200rpm].
It will go from like 12-13.9 and not hold at 14PSI.
I do not have a boost controller, only a 14psi spring in my Tial 38mm Wastegate.
My Setup is a B16a Built motor, Srp 8.x:1 Cr.
Anyone has any info that could help me?
Old Jan 25, 2010 | 08:23 AM
jdm602's Avatar
Default Re: Boost Fluctutates
you sure you have a 14 psi spring?
Old Jan 25, 2010 | 11:00 AM
b20beast83's Avatar
almost positive
Old Jan 25, 2010 | 12:32 PM
jdm602's Avatar
wheres your source for the wg?
i would double check what spring you have. a lot of times itll creep a little so youll run a little more boost than the spring. you usually cant run anything below the wg spring rating.
Old Jan 25, 2010 | 04:34 PM
Turbo-LS's Avatar
sounds like a 12 psi spring with a little bit of creep.
Old Jan 26, 2010 | 03:54 AM
b20beast83's Avatar
source is Intake Mani, shared with bov
Old Jan 26, 2010 | 06:57 AM
Psychoteen101's Avatar
What brand BOV do you have?
Does it build boost consistently or does it jump around?
Old Jan 26, 2010 | 08:13 AM
b20beast83's Avatar
It jumps arround, BOV is TIAL
Old Jan 26, 2010 | 12:48 PM
rick_rabies's Avatar
I'm not Rick!
i have used a 10lb spring in my old wastegate.
i bought a new wastegate and put that spring in it now i get 8-9lb....
weird
Old Jan 26, 2010 | 01:40 PM
Ive had the same thing happen to me with a Tial BOV. Take it apart and rebuild it. Clean it out and lubricate it. Then test it out, see if it fixes your problem.
Old Jan 26, 2010 | 03:23 PM
Turbo-LS's Avatar
IMO the bov should have its own dedicated vacuum course off the manifod for proper operation. Ive teed off other things for a line to my bov and it always gave me weird issues.
That also wasnt just on one specific bov, i always had issues witou a dedicated line to the bov om a greddy type rs, Turbosmart megasonic, tial and now my turbosmart racegate bov. and when put on a single dedicated line they all work flawlessly
Old Jan 26, 2010 | 05:25 PM
jdm602's Avatar
like i said the first time, double check the spring and get back with the color.
also check what spring is in the bov.
Old Jan 26, 2010 | 05:49 PM
Mine is a single dedicated line.
Old Jan 26, 2010 | 06:41 PM
PyroProblem's Avatar
I love your sig psychoteen!
lmfao!
Im gonna guess a sticking/slow responding wastegate?
Old Jan 26, 2010 | 09:35 PM
^^That or the BOV is what im thinking.
Old Jan 27, 2010 | 04:50 AM
b20beast83's Avatar
Where else can i put the Wastegate line?
There is only one port on the Manifold!
Old Jan 27, 2010 | 09:01 AM
jdm602's Avatar
what manifold do you have? there should be more than one port.
buy a vac box and tee it off the big brake booster line that way you have multiple ports you can use and its off a big line so you shouldnt have any problems. thats what i did for one of my cars. no problems after 3 years.
Old Jan 27, 2010 | 10:29 AM
I'm not Rick!
^yeah..especialy if you trying to be clean about things...and you weld all the ports closed on the intake mani.....
Old Jan 27, 2010 | 11:35 AM
Tapping into the intake manifold and threading in a fitting isnt very difficult.
Old Jan 27, 2010 | 11:43 AM
Turbo-LS's Avatar
toward the outlet of the turbo, drill a hole and tap it and put a fitting on there. thats is the best place to get a boost feed for the wastegate. typically though if you have a good intercooler you will see a 1.5-2 psi loss. so if your running a 12 psi spring you would see 10-11 psi of boost because the gate still opens up at 12 psi but the intercooler restricts somewhat
Im running a blox intake manifold same as skunk2 and i use the front nipple for my bov, the rear nipple goes to the brake boost and a vacuum manifold for boost gauge and little things. the WG is hooked to the outlet of the turbo as i just described as well as my boost controller. works flawlessly
Old Jan 28, 2010 | 03:49 PM
Dual Cam Killer's Avatar
im having the same prob, i bought a 9lb spring and am only seeing 7psi. Would I need to buy a 11.6lb spring to see 9-10psi?
Old Jan 29, 2010 | 04:17 AM
b20beast83's Avatar
I *think* i found the problem,
The Bolt that goes into the Barb Fitting was a Smaller BOLT.
I thus changed it to an original Bolt, Hopefully this was the problem.
Is that a possibility?
I will have to datalog to see.
Old Jan 29, 2010 | 11:50 AM
Turbo-LS's Avatar
if you are running the boost feed form the turbo to the wastegate then yes you will need an 11 psi spring to get roughly 9 psi at the intake manifold. or just get a good mbc like a turbosmart and a few clicks will accomplish the same thing
Old Jan 29, 2010 | 02:52 PM
accord_raffi's Avatar
Barb fitting on what?
Old Jan 30, 2010 | 04:45 AM
Thanks bra, i appreciate it.
