Boost Cut
Old Oct 24, 2009 | 06:22 PM
xile6's Avatar
Default Boost Cut
I got a simple question.
I just wanted to know how the boost cut in crome works.
Does it just cut the fuel and you end up pumping just air in the cylinders at that giving psi
Or is there more to it?
Also wouldn't that be bad, wouldn't it cause the motor to be very lean.
Just trying to figure it out, ill be finishing up my kit in a few months and wanted to know if it was something i should use or just rely on the wastegate.
Old Oct 24, 2009 | 06:33 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Boost Cut
should cut fuel and spark, although im not 100% certain. also just putting air in the cylinders is ok as long as there is NO fuel going in with it. you will have a lean condition, but no fuel to make a lean combustion.
ABK
Engine Management and Tuning
Dec 20, 2008 11:49 AM
91crxturbo
Jan 8, 2007 04:48 PM
bard329
Feb 22, 2006 07:02 AM
Sinner
May 24, 2004 10:44 PM
JM Performance
Oct 24, 2001 02:10 PM
