Boost controllers
Old Dec 19, 2008 | 02:47 PM
b20vtech's Avatar
Default Boost controllers
yes, just in here wondering what brand of boost controllers is affordable and works best! I see many people using Greddy Profec B2 but no response if it's good or not, so guys help a brother out finding the right boost controller for his set-up!
thanks
Old Dec 19, 2008 | 04:33 PM
BiggieBert's Avatar
Loved
Community Favorite
More info with your set-up would be helpful! What EMS? I boost control all with Hondata and a AEM solenoid.
Old Dec 19, 2008 | 05:00 PM
boostedcivicsir's Avatar
Mr. Badwrench
my question as well. and my setup as well. works very well. if you are using hondata or neptune, you can use the ecu to control boost.
my 2 experiences with the profec b2 were this. installed them, customers hated them, took them out for mbc's.
Old Dec 19, 2008 | 09:08 PM
Turbo B18C EJ6's Avatar
Im using turboxs dual stage boost controller on neptune, works great. Biggest thing is to get you car to reputable tuner.
Old Dec 19, 2008 | 10:04 PM
b20vtech's Avatar
so u mean i dont even need a boost controller??
btw way this is the set-up
B16 head untouch
RC 750cc
JG edlebrock manifold
68mm TB
GSR cams
Untouch b20b block
Ramhorn manifold
Garrett t3t4 57 trim 63ar
3 in" DP
tial 38 gate
Greddy BOV
350hp intercooler
2.5 charge pipes
walbro fuel pump
Hondata S100
Chipped P28 ECU
Old Dec 19, 2008 | 11:33 PM
Ngataworx's Avatar
no you dont need a boost controller unless you plan to go above 10 psi, remember the wastegate that comes with the kit is spring set at 10 psi. So anything above that you will need a different WG spring or boost controller, but looking at your motor setup 10psi should be perfect.
Old Dec 20, 2008 | 05:34 AM
Mr. Badwrench
should be a little more specific. we are doing it with s300.
Hoe Hopper
Nov 18, 2009 12:19 PM
lovey408
Oct 14, 2007 08:49 PM
screaminvtec
May 23, 2007 10:13 PM
FlatTire
Sep 8, 2004 09:39 PM
Acura_I-RS
Mar 3, 2003 11:56 AM
