Boost controller question
Old Jun 9, 2002 | 06:42 AM
M.A.R.C.'s Avatar
Default Boost controller question
OK I'm trying to get my turbo stuff straight. Learning things here and there. But one thing I'm confused with to this day is... CAN A BOOST CONTROLLER LOWER BOOST... lower than the w/g spring i mean. Thing is I have a DSM T-25... some people saythe w/g opens at 10psi... some say aroudn 7-8psi. If it were 10psi I was thinking I'd have to get a new canister w/ a lower psi spring from TEC but someone told me he tried that and that doesn't work. So i'd need a whole new w/g actuator assembly. So question is... can i lower the boost w/ a mbc or ebc or can it only be raised?
Old Jun 9, 2002 | 08:08 AM
echo999's Avatar
New User
Default Re: Boost controller question (CivicRyda2k)
No. lowest boost is whatever your wastegate is set at.
Old Jun 9, 2002 | 10:12 AM
shadowdawn's Avatar
Default Re: Boost controller question (echo999)
I have a question.
If you have lets say a nice tial wg with a .45 bar (6-7psi) spring... and you get a electronic OR manual boost controller and set them at 7psi... would this help the turbo spool/hit max boost sooner since your not relying on the wg spring and "leaking" like the wg would? Just curious.
Old Jun 9, 2002 | 11:17 AM
Flamenco-T's Avatar
Default Re: Boost controller question (shadowdawn)
yes, if you have a EBC or MBC, thge WG stays shut until the preset boost you had set it on your BC....instead of using a spring loaded controller in a WG...
before I installed my AVC-R, my WG start letting off at 4psi with a .45 bar spring, I can hear it so early while building boost...
then I installed the AVC-R, the WG stayst shut until .55 bar, then it's open all the way like a V8 on crack, kicking all the street cars out there...
Old Jun 9, 2002 | 03:32 PM
SIK IN DA HED's Avatar
New User
Default Re: Boost controller question (Flamenco-NA)
LOL dont forget scarin all the pedestrians on the sidewalk, sometimes causin them to jump into the bushes for fear of their lives!
Old Jun 9, 2002 | 06:31 PM
M.A.R.C.'s Avatar
OK that's what i thought. someone was trying to tell me otherwise but I just wanted to make sure.
gsr x civic
Jun 21, 2007 04:01 AM
94sol
Nov 22, 2006 11:00 AM
killa_lude
Oct 4, 2003 04:56 PM
Dancing is Forbidden
Feb 16, 2003 08:42 AM
accordfreak
Dec 25, 2001 12:20 AM
