Boost controller issue??
Old Aug 5, 2004 | 09:35 PM
G3NR8's Avatar
Default Boost controller issue??
ok...my car has a boost issue. I have a home made boost control I got from a freind. I think it may be the issue, but I guess I need to ask some questions to clarify....
First off, either way I hook up the boost control (by switching around the tubing on the nipples) it does the same thing.....I can't adjust it to under 10+ lbs of boost. My freind drilled a tiny hole in one of the fittings to see what would happen. Basically, as one would expect, the boost went down. Now I can adjust it from 5 Psi at the lowest and up. Is there a problem with running this the way I am? With that tiny hole closed up, it seemed to spool faster, but like I said, I couldn't keep the boost under 10 psi. Could I make the boost controller larger, this way it would hold more air inside it??? I hope I'm not making this confusing I just want to make sure what I am doing is ok. If I need to clarify in any way lemme know
bigtom388
Nov 21, 2009 12:30 PM
ATS*Mark
Feb 18, 2004 01:25 PM
HybridCoupe
Jun 28, 2002 05:13 PM
