Boost control problem
Old Jul 15, 2002 | 05:23 PM
b00stedbyFastrax's Avatar
Default Boost control problem
stock wastegate boost is 10 psi. using profec b to up boost to 15 psi. the problem is that boost swings up to 10 psi and then struggle to 15 psi. now the other odd problem is that after I shut off the profec b to run stock wastegate boost (10psi), the same thing happens again. it swings to 10 psi and struggle to 15 psi ! and the boost controller is off!! is my wastegate gone bad??
Old Jul 15, 2002 | 05:27 PM
ekb18c's Avatar
Default Re: Boost control problem (BoostedbyFastrax)
if you have a 10psi spring in your wastegate then it shouldnt creep up to 15psi, unless your wastegate is broken.
CX-T
Jun 19, 2008 09:22 AM
afrothunda713
Jul 10, 2006 09:40 AM
Turbo-charged
Apr 1, 2005 08:32 AM
Drew Peacock
Sep 5, 2004 10:36 PM
G U E C O
Dec 9, 2003 02:43 PM
