boost control
Old Jul 1, 2002 | 02:24 PM
CiViC SiR's Avatar
Default boost control
how can increas the boost from 5 to 7.5 Psi without boost controler?
Old Jul 1, 2002 | 02:29 PM
rioninja's Avatar
Default Re: boost control (CiViC SiR)
you cant, unless you have an internal wastegate with an adjustable actuator rod.
Go read up in the forced induction forum before you ask questions like this again. I'm not knocking you, but it sounds like you really dont know whats going on with your turbo setup.
Old Jul 1, 2002 | 02:57 PM
RexB16's Avatar
Default Re: boost control (RioNinja)
[QUOTE but it sounds like you really dont know whats going on with your turbo setup.[/QUOTE]
which is a VERY scary thing when ur running a turbo on a car that was never intended to have one.
Old Jul 1, 2002 | 07:08 PM
kidkutz's Avatar
Default Re: boost control (RexB16)
if you have a turbonetics wastegate you can adjust it
Old Jul 1, 2002 | 07:42 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: boost control (kidkutz)
Yes, definitely read up on turbochargers. You should be able to adjust it somewhat without a BC. What kind of wastegate do you have? Internal/external?
[Modified by shamoo, 11:42 PM 7/1/2002]
Old Jul 1, 2002 | 11:53 PM
SIK IN DA HED's Avatar
New User
Default Re: boost control (shamoo)
at least buy a manual controller. its only $50 shipped to your door.
Old Jul 2, 2002 | 12:03 AM
Mr. Softee's Avatar
Default Re: boost control (dlplayboy)
go to c speed, you can make one for like 5$.
Old Jul 3, 2002 | 12:21 AM
CiViC SiR's Avatar
my wesgate is external
Old Jul 3, 2002 | 12:43 AM
PureTeg420's Avatar
You can either swap springs inside the wastegate (which isn't worth it), or get a boost controller. Just make a cheap manual controller if you don't want to spend any money on an electric one
Old Jul 3, 2002 | 06:00 AM
shamoo's Avatar
Default Re: boost control (94goldjungsr)
Just watch out for those. When they heat up, they can really spike. They are reliable until after about 10 minutes of driving.
Old Jul 3, 2002 | 12:20 PM
PyroVTEC's Avatar
New User
If you're reallllllllllllllllllllly bloody cheap, you could just yank out the vacuum line running to the wastegate... you'll run really fast for several seconds...
... of course, that's if you don't mind a blown engine...
Old Jul 3, 2002 | 04:48 PM
ion_four's Avatar
Do they still change if you've isolated them from the heat?
Old Jul 3, 2002 | 05:25 PM
rice4life's Avatar
Default Re: boost control (ion_four)
you can just use a plastic T between the boost line to your waste gate. the more T's you put in the higher the boost. i used this at the track before i got the avc-r
Old Jul 3, 2002 | 08:21 PM
turbo Si's Avatar
Default Re: boost control (rice4life)
That is exactly what I did. We just put in one tee though and the longer the vacum line that conected to the tee was then the more boost it created. This is not something I would keep and rely on though.
Old Jul 3, 2002 | 08:33 PM
93LSivic's Avatar
Default Re: boost control (turbo Si)
I remember seeing a way of upping the boost for very, very cheap. It required taking a brass tube, drilling some small holes in it and putting it inline with the vacuum line going to the wastegate.
I wouldnt try this, but I remember seeing it somewhere years ago.
Old Jul 5, 2002 | 06:37 AM
shamoo's Avatar
Default Re: boost control (93LSivic)
I'm sure the previous three ways listed are simply just to bleed off boost that is read directly from the compressor.
It's not perfectly safe, but it'll work temporarily.
superhatchbackbros
Jun 30, 2007 09:17 AM
Broken Gearbox
Jun 8, 2003 02:12 PM
smallttocs
Mar 2, 2003 12:30 AM
teamrocket si
Feb 10, 2002 02:27 PM
