boost control
Old Jul 12, 2006 | 09:47 AM
high boosted rex's Avatar
Default help with boost control
on the dyno i have no control of the boost, i'm using a tial 44mm wastegate with a 8psi spring,ramhorn manifold, h22a with 9.1 pistons, eagle rods, sleeves, arp studs etc. at about 4600rpm the turbo takes off to about 18psi, the turbo is a precision 5252e, full 3inch exhaust, what can be causing this, i'm thinking of adding another wastegate, what do u guys think???
Modified by high boosted rex at 11:15 AM 7/12/2006
Old Jul 12, 2006 | 12:01 PM
Default Re: help with boost control (high boosted rex)
anyone???
Old Jul 12, 2006 | 12:39 PM
shortyz21's Avatar
u got your vac line on the bottom nipple right?
Old Jul 12, 2006 | 12:58 PM
PM-Performance's Avatar
why do you have an 8PSi spring in the WG? maybe its too small and causing that problem. Ive been there and done that just with a much bigger turbo. i couldnt keep it below 14-15 psion a 10psi spring
Old Jul 12, 2006 | 01:22 PM
Topdawgg's Avatar
tapping the wastegate at the proper hole? ive never had that problem... check the line also
Old Jul 13, 2006 | 07:06 AM
Default Re: (Topdawgg)
yup, the vac line is on the lower nipple, thats the right place for it, the vac line is good, on the run the wastegate isn't opening at all, there is nothing coming out of it, its like its closed shut. someone suggested adding another wastegate???
Old Jul 13, 2006 | 08:08 AM
here are some pics of the setup
someone suggested that the flow is to great and can't make the 90degree bend to the wastegate cause the airflow to bypass wastegate.. What do u think??
Old Jul 13, 2006 | 08:33 AM
J.C. ALL STAR's Avatar
the wastegate HAS to be stuck closed.check all vacume lines and pull the wastegate to see if you can puch the plunger in with your thumb to make sure there is nothing physically interfering with it.
Old Jul 13, 2006 | 01:41 PM
Default Re: (I_HATE)
will try.. Any other suggestions??
Old Jul 13, 2006 | 06:07 PM
qfast817's Avatar
Default Re: (high boosted rex)
the wg line looks to long, try hooking the bc closer to the wg
Old Jul 13, 2006 | 06:24 PM
DaveF's Avatar
Default Re: (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">the wg line looks to long, try hooking the bc closer to the wg</TD></TR></TABLE>
where do you see a wg line ?????????????????????????????????????????????
Old Jul 13, 2006 | 06:29 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
where do you see a wg line ?</TD></TR></TABLE>
yeah really.
Old Jul 13, 2006 | 06:52 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (boostedcivicsir)
there is no wg line
Old Jul 14, 2006 | 07:58 AM
the pics show the setup up.. but not finished.. i don't have pics of finished yet
Old Jul 14, 2006 | 08:02 AM
B6tPoweredMx3's Avatar
what size wastegate line are you running?
Old Jul 14, 2006 | 09:01 AM
r6king28's Avatar
check the vacum lines on the wastegate
Old Jul 14, 2006 | 07:10 PM
Cramerox's Avatar
LOL I think thats the oil line you are talking about.
94EGZI
Nov 10, 2008 03:32 PM
H22TurboNos
May 13, 2007 01:06 PM
TurbodTegSfaria
Oct 14, 2006 07:28 AM
Turbocivic94
Aug 7, 2003 05:39 AM
turbo se
Jun 13, 2003 11:33 AM
