Boost Contorller
Old Mar 28, 2003 | 07:04 AM
Screamer's Avatar
Default Boost Contorller
Which boost controller should I go with??? I am planning on boosting up to about 24-26psi and I am not sure which boost contrller can handle that kind of boost with a small spring in the WG. I will be tooning it to about 7-9psi on the street and than have two more settings for 14-16psi and 24-26psi. What is a good contorller to go with.
I have also heard that Profec B is not that great and it only allows adjustment of up to 14psi is this ture???
Thanks,
Rafal
Old Mar 28, 2003 | 07:06 AM
b18bturbo's Avatar
Default Re: Boost Contorller (Screamer)
profec b can go up to whatever you have actually it can handle any boost as long as your wg spring is set correctly.
If you have tial wg most controllers can only double the wg output..
The best bet if you want a nice controller that can do alot of different things get the innovative unit hte msbc-1 its around 599.95 or so but its gear based great for high boost applications.
Old Mar 28, 2003 | 10:06 AM
Screamer's Avatar
Default Re: Boost Contorller (b18bturbo)
Thanks for your reply. So what you are saying is that if I go with a 35mm Tial WG the boost controller will only allow me to up the PSI double the spring rate?? Therefore 9psi (.65) spring will only allow my boost controller to go to 18psi total boost???
What I am trying to do is do as simple setup as possible, but still do it correctly. I don't really like the flashy screes will all the different options that I will never use.
Old Mar 28, 2003 | 11:00 AM
alpha's Avatar
I second what b18bturbo said. I would also suggest taking a look at the Blitz Dual SBC Spec-R boost controller.
Old Mar 28, 2003 | 11:04 AM
wickedxboi's Avatar
Default Re: Boost Contorller (0x64)
i know that the apexi avcr will allow to you have 3 or more boost settings. maybe take a look into that
b16 matt's Avatar
Greddy profec-b
Old Mar 28, 2003 | 12:29 PM
GSRwBOOST's Avatar
Default Re: Boost Contorller (b16matt)
someone correct me if i'm wrong but you dont want, say a 3lb spring and a bc to push it to 26psi..... it will either not work right or cause problems....
you want a wastegate spring closer to your minimum level of boost as possible..
if you run 10 daily... get a spring close to that and then boost it higher with the b/c....
anyone?
btw: I used the Blitz DSBC and it was good to 2bar.... easy to setup and use.
Old Mar 28, 2003 | 01:26 PM
Screamer's Avatar
Default Re: Boost Contorller (GSRwBOOST)
How is the Profec A? Anyone has any experience with it. I am about to get one for $200us is this a good price???
Thanks,
Rafal
Old Mar 28, 2003 | 02:29 PM
drewspeed's Avatar
anyone?
I agree
[Modified by drewspeed, 3:29 PM 3/28/2003]
Old Mar 29, 2003 | 07:26 PM
Screamer's Avatar
Thanks for the great replies. I orderd my Tial 35/40mm Hybrid WG yesterday with a 9psi spring so it should be fine for daily driving. Now I need to get a contorller. How is the profec A anyone any experience with them??? I can get a good deal on one, are they worth the money??? And if they are why were they discontinued???
Thanks,
Rafal
Old Mar 29, 2003 | 08:00 PM
V-SPEC 1's Avatar
Where can I get this product? anybody have one of this BC? and how do you like it?
mrbsponge
May 30, 2006 06:00 AM
c61lude
Jan 19, 2006 04:34 PM
turbo95eg6
Jun 12, 2005 12:15 PM
accordfreak
Dec 25, 2001 12:20 AM
